12.9‑inch iPad Pro Card Readers
Browse Card Readers for 12.9‑inch iPad Pro
Sort by:
Narrow By:
Aluratek MicroSD / MiniSD USB2.0 Multi-Media Card Reader for 12.9‑inch iPad ProAluratek MicroSD / MiniSD USB2.0 Multi-Media Card Reader for 12.9‑inch iPad Pro
The AUCR202 provides a convenient way of transferring data between your cellular phone or camera and computer. This is the perfect solution to transfer all of the pictures sitting in your phone of camera to your computer. You can also transfer MP3 music from your computer to your phone. Simply insert your cellular memory card such as micro SD or your cameras SD card (multiple cards types are supported) into the media slot and plug into your computers USB port and you are ready to start transferring. No software installation or power is necessary. Your media will appear as a removable drive on your computer and simply drag and drop all your data using your mouse. It's that easy.
CAD 13.99  $19.99'Not yet rated.'In StockAdd Aluratek MicroSD / MiniSD USB2.0 Multi-Media Card Reader for 12.9‑inch iPad Pro to Cart
More Memory Cards...
My 12.9‑inch iPad Pro
Shop by Category
Trending Purchases
Customer Care
Powered by...
Our Customers Say...
