12.9‑inch iPad Pro Clearance
Browse Clearance for 12.9‑inch iPad Pro
Sort by:
Narrow By:
BlackBerry Screen Wipe for 12.9‑inch iPad ProBlackBerry Screen Wipe for 12.9‑inch iPad Pro
Helps remove fingerprints, dust, makeup and more from your phone's screen
Free Shipping
CAD 5.00  $12.95Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5 (31)In StockAdd BlackBerry Screen Wipe for 12.9‑inch iPad Pro to Cart
Griffin Technology Stylus for 12.9‑inch iPad ProGriffin Technology Stylus for 12.9‑inch iPad Pro
Griffin's Stylus is a balanced pointer with a soft rubber tip custom designed to mimic your finger and features an omni-directional tip adapts to any writing style.
CAD 9.95  $19.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)Out of StockAdd Griffin Technology Stylus for 12.9‑inch iPad Pro to Cart
Plantronics BackBeat Go 2.0 Bluetooth Stereo Headphones for 12.9‑inch iPad ProPlantronics BackBeat Go 2.0 Bluetooth Stereo Headphones for 12.9‑inch iPad Pro
Plantronics BackBeat GO 2.0 wireless earbuds, incredibly small, amazingly light. No wires, no hassle, no compromise. Easily slips into your pocket, but still packs full?on stereo sound. So you can listen to music, chat with friends, or watch movies on your tablet. Even play games on the go. And Bluetooth technology makes it a snap to connect wirelessly. There are three sizes of cushioned eartips and two stabilizers for a secure, comfortable fit. Incoming call? Inline controls let you pause music to take a call, change volume, or skip tracks. Great sound in a small package. BackBeat GO 2.0. Get Going.
Free Shipping
CAD 79.95  $99.99Score 3.6/5Score 3.6/5Score 3.6/5Score 3.6/5Score 3.6/5 (5)Ships 3/28Add Plantronics BackBeat Go 2.0 Bluetooth Stereo Headphones for 12.9‑inch iPad Pro to Cart
Plantronics Voyager Legend Charge Cable for 12.9‑inch iPad ProPlantronics Voyager Legend Charge Cable for 12.9‑inch iPad Pro
This spare, 9-inch USB charge cable is ideal for recharging your Plantronics Voyager Legend headset from your laptop’s USB port.
CAD 11.99  $24.95'Not yet rated.'In StockAdd Plantronics Voyager Legend Charge Cable for 12.9‑inch iPad Pro to Cart
MiPow 4000 mAh Lightning Power Tube (Purple) for 12.9‑inch iPad ProMiPow 4000 mAh Lightning Power Tube (Purple) for 12.9‑inch iPad Pro
'Made for iPod' & 'Made for iPhone' certified Built-in Apple Lightning connector Support charging to two devices at the same time.
CAD 44.99  $79.99'Not yet rated.'In StockAdd MiPow 4000 mAh Lightning Power Tube (Purple) for 12.9‑inch iPad Pro to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for 12.9‑inch iPad ProweBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for 12.9‑inch iPad Pro
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 3/29Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for 12.9‑inch iPad Pro to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for 12.9‑inch iPad ProweBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for 12.9‑inch iPad Pro
CAD 34.99  $44.99'Not yet rated.'Ships 3/29Add weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for 12.9‑inch iPad Pro to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for 12.9‑inch iPad ProweBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for 12.9‑inch iPad Pro
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Ships 3/29Add weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for 12.9‑inch iPad Pro to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for 12.9‑inch iPad ProweBoost NMO Antenna 800/1900 MHz Omni Directional for 12.9‑inch iPad Pro
CAD 19.99  $26.99'Not yet rated.'Ships 3/29Add weBoost NMO Antenna 800/1900 MHz Omni Directional for 12.9‑inch iPad Pro to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for 12.9‑inch iPad ProweBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for 12.9‑inch iPad Pro
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for 12.9‑inch iPad Pro to Cart
weBoost Marine Antenna Mount (901119) for 12.9‑inch iPad ProweBoost Marine Antenna Mount (901119) for 12.9‑inch iPad Pro
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for 12.9‑inch iPad Pro to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for 12.9‑inch iPad ProweBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for 12.9‑inch iPad Pro
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for 12.9‑inch iPad Pro to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for 12.9‑inch iPad ProweBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for 12.9‑inch iPad Pro
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for 12.9‑inch iPad Pro to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for 12.9‑inch iPad ProweBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for 12.9‑inch iPad Pro
CAD 39.99  $49.99'Not yet rated.'Ships 3/29Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for 12.9‑inch iPad Pro to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for 12.9‑inch iPad ProweBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for 12.9‑inch iPad Pro
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 3/29Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for 12.9‑inch iPad Pro to Cart
weBoost DC 12v Hardwire Power Kit for 12.9‑inch iPad ProweBoost DC 12v Hardwire Power Kit for 12.9‑inch iPad Pro
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for 12.9‑inch iPad Pro to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for 12.9‑inch iPad ProweBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for 12.9‑inch iPad Pro
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for 12.9‑inch iPad Pro to Cart
weBoost Home Accessory Kit for Sleek Amp for 12.9‑inch iPad ProweBoost Home Accessory Kit for Sleek Amp for 12.9‑inch iPad Pro
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for 12.9‑inch iPad Pro to Cart
weBoost Battery Pack for 12.9‑inch iPad ProweBoost Battery Pack for 12.9‑inch iPad Pro
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for 12.9‑inch iPad Pro to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for 12.9‑inch iPad ProweBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for 12.9‑inch iPad Pro
CAD 35.99  $35.99'Not yet rated.'Ships 3/29Add weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for 12.9‑inch iPad Pro to Cart
CyberPower Essential 3-Outlets Surge Suppressor Wall Tap Plug (CSB300W) for 12.9‑inch iPad ProCyberPower Essential 3-Outlets Surge Suppressor Wall Tap Plug (CSB300W) for 12.9‑inch iPad Pro
The CyberPower Essential Series CSB300W Surge Suppressor is ideal for Home/Office protection with 900 joules, 3 outlets, and wall tap plug. Its works great for protecting personal computers, wireless/VoIP routers, cable/DSL modems, tablet chargers and other personal electronics.
CAD 9.99  $19.99'Not yet rated.'In StockAdd CyberPower Essential 3-Outlets Surge Suppressor Wall Tap Plug (CSB300W) for 12.9‑inch iPad Pro to Cart
Belkin USB Extender Cable for 12.9‑inch iPad ProBelkin USB Extender Cable for 12.9‑inch iPad Pro
The Pro Series USB Extension Cable extends the length of your USB device cable to your hub, PC, or Mac. Perfect for devices with short cables. Molded strain relief and PVC overmolding to ensure a lifetime of error-free data transmissions.
Free Shipping
CAD 6.99  $9.99'Not yet rated.'Ships 3/27Add Belkin USB Extender Cable for 12.9‑inch iPad Pro to Cart
Parrot Minikit Neo 2 HD Handsfree Car Kit for 12.9‑inch iPad ProParrot Minikit Neo 2 HD Handsfree Car Kit for 12.9‑inch iPad Pro
The MINIKIT Neo 2 HD combines the best of technology in a compact and stylish design. Make and receive calls without touching any buttons and enhance your experience with the free application for Android and iPhone.
Free Shipping
CAD 99.99  $119.99'Not yet rated.'In StockAdd Parrot Minikit Neo 2 HD Handsfree Car Kit for 12.9‑inch iPad Pro to Cart
Belkin 6-Outlets Surge Suppressor for 12.9‑inch iPad ProBelkin 6-Outlets Surge Suppressor for 12.9‑inch iPad Pro
This Home/Office 6-Outlets Surge Suppressor provides premium power protection for small home appliances, and other connected devices. Our decades of research and development have led us to the release of this breakthrough product. We've used advanced design elements, top-quality construction, and superior circuitry and components to provide the most complete protection from power surges, spikes, and AC contamination available. This surge suppressor protects everyday household electronics. Its slim, sleek design blends seamlessly with today's modern electronics and appliances.
CAD 12.99  $19.99'Not yet rated.'Out of StockAdd Belkin 6-Outlets Surge Suppressor for 12.9‑inch iPad Pro to Cart
BlackBerry Bold 9900 A++ Grade Certified Refurbished Series Unlocked Phone - BlackBlackBerry Bold 9900 A++ Grade Certified Refurbished Series Unlocked Phone - Black
A++ Grade Certified Refurbished Series BlackBerry Bold 9900, black. Unlocked. Very limited quantities. Includes BlackBerry Wall Charger.
Free Shipping
CAD 139.95  $249.99'Not yet rated.'In StockAdd BlackBerry Bold 9900 A++ Grade Certified Refurbished Series Unlocked Phone - Black to Cart
Mobi Products T2 Torx Magnetic Screwdriver (0.93mm = 0.036 in) for 12.9‑inch iPad ProMobi Products T2 Torx Magnetic Screwdriver (0.93mm = 0.036 in) for 12.9‑inch iPad Pro
Affordable T2 Torx Screw Driver ideal for mobile phone repairs. Always handy to have. Before purchasing, make sure to double check that this is the type of screwdriver you need for your type of repair/mobile phone model.
CAD 2.99  $3.99'Not yet rated.'Out of StockAdd Mobi Products T2 Torx Magnetic Screwdriver (0.93mm = 0.036 in) for 12.9‑inch iPad Pro to Cart
Mobi Products T5 Torx Magnetic Screwdriver (0.055"=1.42 mm) for 12.9‑inch iPad ProMobi Products T5 Torx Magnetic Screwdriver (0.055"=1.42 mm) for 12.9‑inch iPad Pro
Affordable T5 Torx Screw Driver ideal for mobile phone repairs. Always handy to have. Before purchasing, make sure to double check that this is the type of screwdriver you need for your type of repair/mobile phone model.
CAD 1.99  $3.99'Not yet rated.'In StockAdd Mobi Products T5 Torx Magnetic Screwdriver (0.055"=1.42 mm) for 12.9‑inch iPad Pro to Cart
Mobi Products T3 Torx Magnetic Screwdriver (0.046" = 1.10mm) for 12.9‑inch iPad ProMobi Products T3 Torx Magnetic Screwdriver (0.046" = 1.10mm) for 12.9‑inch iPad Pro
Affordable T3 Torx Screw Driver ideal for mobile phone repairs. Always handy to have. Before purchasing, make sure to double check that this is the type of screwdriver you need for your type of repair/mobile phone model.
CAD 0.99  $3.99'Not yet rated.'In StockAdd Mobi Products T3 Torx Magnetic Screwdriver (0.046" = 1.10mm) for 12.9‑inch iPad Pro to Cart
Visiontek Lightning 0.25m Apple approved Cable - Black for 12.9‑inch iPad ProVisiontek Lightning 0.25m Apple approved Cable - Black for 12.9‑inch iPad Pro
The VisionTek Lightning to USB 3.0/2.0 Charge & Sync Cable helps you make a reliable and affordable connection to Apple Lightning mobile iDevices.
CAD 9.99  $24.99'Not yet rated.'Ships 3/28Add Visiontek Lightning 0.25m Apple approved Cable - Black for 12.9‑inch iPad Pro to Cart
MYBAT Noodle SYNC CABLE for Lightning (Black) for 12.9‑inch iPad ProMYBAT Noodle SYNC CABLE for Lightning (Black) for 12.9‑inch iPad Pro
This MYBAT Noodle SYNC CABLE for Lightning (Black) connects your 12.9‑inch iPad Pro to your computer's USB port for syncing and charging.
CAD 5.99  $19.99'Not yet rated.'In StockAdd MYBAT Noodle SYNC CABLE for Lightning (Black) for 12.9‑inch iPad Pro to Cart
APC SurgeArrest Essential 7 Outlet Surge Suppressor for 12.9‑inch iPad ProAPC SurgeArrest Essential 7 Outlet Surge Suppressor for 12.9‑inch iPad Pro
Lightning and power surges can permanently ruin your electronic equipment. Changes in voltage cause lockups and loss of work. This unit will protect your equipment from the threat of bad power. The SurgeArrest Essential 7 Outlet Surge Suppressor offers a great value for home equipment and business applications such as small office/home computers.
CAD 13.99  $24.99'Not yet rated.'In StockAdd APC SurgeArrest Essential 7 Outlet Surge Suppressor for 12.9‑inch iPad Pro to Cart
Belkin 6-Outlet Wall Mount Surge Protector for 12.9‑inch iPad ProBelkin 6-Outlet Wall Mount Surge Protector for 12.9‑inch iPad Pro
The 6-Outlet Wall Mount Surge Protector is perfect for your general electronics, home appliances, and more. It mounts directly over any existing wall outlet to give you extra outlets without extra cords Essential power filtration keeps your devices performing at their best.
CAD 12.99  $17.99'Not yet rated.'In StockAdd Belkin 6-Outlet Wall Mount Surge Protector for 12.9‑inch iPad Pro to Cart
Apple 12W USB Power Adapter for 12.9‑inch iPad ProApple 12W USB Power Adapter for 12.9‑inch iPad Pro
Your 12.9‑inch iPad Pro display includes a 12W USB Power Adapter for charging directly through an electrical outlet. Purchase this additional adapter to have a second charger for home or office.
CAD 23.99  $25.00'Not yet rated.'In StockAdd Apple 12W USB Power Adapter for 12.9‑inch iPad Pro to Cart
iQ 5.2A Bullet Car Charger With 3 USB Ports for 12.9‑inch iPad ProiQ 5.2A Bullet Car Charger With 3 USB Ports for 12.9‑inch iPad Pro
Charge up to 3 devices rapidly with this IQ 5.2A Bullet Car Charger. 2 Year Warranty by IQ in Canada.
CAD 14.99  $29.99'Not yet rated.'In StockAdd iQ 5.2A Bullet Car Charger With 3 USB Ports for 12.9‑inch iPad Pro to Cart
Plantronics Voyager Legend UC B235-M Bluetooth Headset System for 12.9‑inch iPad ProPlantronics Voyager Legend UC B235-M Bluetooth Headset System for 12.9‑inch iPad Pro
The Voyager Legend UC was designed to provide the convenience of one headset for use with multiple devices - PC, smartphone or tablet. The Bluetooth mini USB adapter can stay in your laptop USB port for always-ready PC connectivity or can be stored in the included portable charging case.
Free Shipping
CAD 169.99  $199.99'Not yet rated.'Pre-OrderAdd Plantronics Voyager Legend UC B235-M Bluetooth Headset System for 12.9‑inch iPad Pro to Cart
Visiontek Lightning to USB 1 Meter Cable (Apple Approved) for 12.9‑inch iPad ProVisiontek Lightning to USB 1 Meter Cable (Apple Approved) for 12.9‑inch iPad Pro
The VisionTek Lightning to USB 3.0/2.0 Charge & Sync Cable helps you make a reliable and affordable connection to a wide variety of Apple mobile iDevices. With full compatibility with iOS 7, you'll enjoy error-free use while connecting to a Mac or PC's USB port for charging and data syncing. At over three feet in length, this handy cable offers device placement flexibility. Don't get caught not being able to charge in the car or office... this cable makes it the affordable spare cable solution.
CAD 8.99  $19.99'Not yet rated.'In StockAdd Visiontek Lightning to USB 1 Meter Cable (Apple Approved) for 12.9‑inch iPad Pro to Cart
Griffin Technology MultiDock Cradle for 12.9‑inch iPad ProGriffin Technology MultiDock Cradle for 12.9‑inch iPad Pro
Charging and storage for multiple iPads, tablets and smartphones. MultiDock is a single, space-efficient charging station for storing, charging, and syncing 10, 20 or even 30 iPad tablets, iPhones, iPods or other devices. Its footprint is minimal: only slightly larger than a laptop computer. But in that space, each MultiDock unit packs storage, charging, and syncing capability for 10 tablets. Stack 3 MultiDocks together to sync 30 tablets in the same amount of counter space, from a single host computer. MultiDock uses Griffin's exclusive ChargeSensorTM technology to optimize charging. ChargeSensorTM automatically detects the charging characteristics of each connected device and supplies the charging rate - up to 10 watts (5 volts @ 2.1 amps) of charging power per bay - each device needs for fastest, most complete charging.Connecting an iPad 4, iPad mini or other device that uses Apple's new Lightning charge/sync connector automatically activates MultiDock's Quick Charge Mode. MultiDock charges these newer devices at the fastest possible rate, even while syncing, thus ensuring that your devices will be fully charged and ready when you need them.And you won't have to remove your tablets from their cases: each MultiDock charging bay accommodates even bulky protective cases. At 1.25" wide, MultiDock's charging slots are the widest available.MultiDock is designed for easily securing it on a table, desk, or countertop. Included hardware allows installations that stack up to three units in one space.MultiDock is available in two configurations; a single unit and a stacked unit capable of handling up to 30 devices. The stacked unit ships assembled, with smooth rolling casters, grab handle and a lockable laptop tray to secure the host laptop.
Free Shipping
CAD 649.99  $999.99'Not yet rated.'Pre-OrderAdd Griffin Technology MultiDock Cradle for 12.9‑inch iPad Pro to Cart
Optex Screenmate LCD Screen Writing Stylus and Cleaner for 12.9‑inch iPad ProOptex Screenmate LCD Screen Writing Stylus and Cleaner for 12.9‑inch iPad Pro
Ergonomic and compact stylus designed for comfort and convenience.
CAD 1.99  $16.95Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (2)In StockAdd Optex Screenmate LCD Screen Writing Stylus and Cleaner for 12.9‑inch iPad Pro to Cart
mophie Power Boost Mini 2,600mAh External Battery for 12.9‑inch iPad Promophie Power Boost Mini 2,600mAh External Battery for 12.9‑inch iPad Pro
Keep your portable devices charged by the #1-selling battery brand-introducing power boost mini universal battery by mophie. Compact and easy to carry, the power boost mini battery will keep your smartphone or wearables charged when you most need it. Available in a variety of colors, this is the companion your portable devices just cant live without. Connect any smartphone or wearable to the power boost mini batterys USB port and press the status button to start charging. The LED battery indicator tells you the power boost mini batterys charge level. Recharge your power boost mini battery by plugging the included micro USB cable into a USB wall adapter or laptop.
CAD 9.99  $19.99'Not yet rated.'In StockView mophie Power Boost Mini 2,600mAh External Battery for 12.9‑inch iPad Pro Options
My 12.9‑inch iPad Pro
Shop by Category
Customer Care
Powered by...
Our Customers Say...
