12.9‑inch iPad Pro Memory Cards
Browse Memory Cards for 12.9‑inch iPad Pro
Sort by:
Narrow By:
Aluratek MicroSD / MiniSD USB2.0 Multi-Media Card Reader for 12.9‑inch iPad ProAluratek MicroSD / MiniSD USB2.0 Multi-Media Card Reader for 12.9‑inch iPad Pro
The AUCR202 provides a convenient way of transferring data between your cellular phone or camera and computer. This is the perfect solution to transfer all of the pictures sitting in your phone of camera to your computer. You can also transfer MP3 music from your computer to your phone. Simply insert your cellular memory card such as micro SD or your cameras SD card (multiple cards types are supported) into the media slot and plug into your computers USB port and you are ready to start transferring. No software installation or power is necessary. Your media will appear as a removable drive on your computer and simply drag and drop all your data using your mouse. It's that easy.
CAD 13.99  $19.99'Not yet rated.'In StockAdd Aluratek MicroSD / MiniSD USB2.0 Multi-Media Card Reader for 12.9‑inch iPad Pro to Cart
Kingston 16GB DataTraveler 100 G3 USB 3.0 Flash Drive for 12.9‑inch iPad ProKingston 16GB DataTraveler 100 G3 USB 3.0 Flash Drive for 12.9‑inch iPad Pro
Kingston's Data Traveler 100 G3 (DT100G3) USB Flash drive is compliant with next-generation USB 3.0 specifications to take advantage of technology in newer notebooks, desktop PCs and digital devices. With DT100G3, storing and transferring of documents, presentations, music, video, and more is quicker and easier than ever. DT100G3 features a sleek, cost-effective design to make the transition to a satisfying USB 3.0 experience a minimal investment. DT100G3 is backward compatible with USB 2.0 and has five-year warranty. Future-proof your portable storage now!
CAD 10.49  $14.99'Not yet rated.'In StockAdd Kingston 16GB DataTraveler 100 G3 USB 3.0 Flash Drive for 12.9‑inch iPad Pro to Cart
Kingston 16GB DataTraveler G4 USB 3.0 Flash Drive for 12.9‑inch iPad ProKingston 16GB DataTraveler G4 USB 3.0 Flash Drive for 12.9‑inch iPad Pro
Kingston's Data Traveler Generation 4 (DTIG4) USB Flash drive features USB 3.0 for quick and easy transfers of music, video and more. Its practical design and fashionable colors make it ideal for everyday use at work, home, school or wherever you need to take your data. It's backwards compatible with existing USB 2.0 ports, allowing 2.0 users to migrate to 3.0 in the future without replacing their drive. Data Traveler Generation 4 is backed by a five - year warranty, free technical support and legendary Kingston reliability. The large, colorful loop easily attaches to your key ring, the practical cap protects the USB plug and your data.
Free Shipping
CAD 9.99  $12.99'Not yet rated.'In StockAdd Kingston 16GB DataTraveler G4 USB 3.0 Flash Drive for 12.9‑inch iPad Pro to Cart
Kingston 32GB DataTraveler G4 USB 3.0 Flash Drive for 12.9‑inch iPad ProKingston 32GB DataTraveler G4 USB 3.0 Flash Drive for 12.9‑inch iPad Pro
Kingston's Data Traveler Generation 4 USB Flash drive features USB 3.0 for quick and easy transfers of music, video and more. Backwards also compatible with existing USB 2.0 ports, allowing 2.0 users to migrate to 3.0 in the future without replacing their drive. Five-year warranty by KINGSTON.
CAD 19.99  $29.99'Not yet rated.'Ships 5/25Add Kingston 32GB DataTraveler G4 USB 3.0 Flash Drive for 12.9‑inch iPad Pro to Cart
Leef iAccess iOS microSD Reader (LightningExternal) for 12.9‑inch iPad ProLeef iAccess iOS microSD Reader (LightningExternal) for 12.9‑inch iPad Pro
The Leef iAccess iOS microSD Card Reader is the easiest way to infinite memory. The reader is expandable in nature, so you are never limited by the quality or quantity of footage you want to view or edit. It's also a great choice for action cameras.
Free Shipping
CAD 69.99  $93.27'Not yet rated.'In StockAdd Leef iAccess iOS microSD Reader (LightningExternal) for 12.9‑inch iPad Pro to Cart
Leef iBridge 64GB Mobile Memory iOS USB Flash Drive with Lightning Connector for Apple (Black) for 12.9‑inch iPad ProLeef iBridge 64GB Mobile Memory iOS USB Flash Drive with Lightning Connector for Apple (Black) for 12.9‑inch iPad Pro
Running out of memory on your iOS device? The Leef iBRIDGE expands the storage capacity of your compatible Apple device giving you the freedom and flexibility to do more. Take your movie or music collections with you on the iBRIDGE, all without using internal memory or data. You can also record video and capture photos directly to the iBRIDGE.
Free Shipping
CAD 129.99  $169.99'Not yet rated.'In StockAdd Leef iBridge 64GB Mobile Memory iOS USB Flash Drive with Lightning Connector for Apple (Black) for 12.9‑inch iPad Pro to Cart
Kingston 128GB USB3.0 DataTraveller 100 G3 for 12.9‑inch iPad ProKingston 128GB USB3.0 DataTraveller 100 G3 for 12.9‑inch iPad Pro
128GB USB 3.0 DataTraveler 100 G3
Free Shipping
CAD 69.99  $79.99'Not yet rated.'Ships 5/25Add Kingston 128GB USB3.0 DataTraveller 100 G3 for 12.9‑inch iPad Pro to Cart
Kingston 16GB Datatraveler G4 USB 3.0 Flash Drive for 12.9‑inch iPad ProKingston 16GB Datatraveler G4 USB 3.0 Flash Drive for 12.9‑inch iPad Pro
Kingston's DataTraveler Generation 4 (DTIG4) USB Flash drive features USB 3.0 for quick and easy transfers of music, video and more. Its practical design and fashionable colors make it ideal for everyday use at work, home, school or wherever you need to take your data.
CAD 14.99  $19.99'Not yet rated.'Ships 5/25Add Kingston 16GB Datatraveler G4 USB 3.0 Flash Drive for 12.9‑inch iPad Pro to Cart
Iogear SD/MicroSD/MMC Card Reader/Writer for 12.9‑inch iPad Pro45%Iogear SD/MicroSD/MMC Card Reader/Writer for 12.9‑inch iPad Pro
IOGEAR's GFR204SD Secure Digital cards are ubiquitous in consumer electronic devices and have become the dominant means of storing several gigabytes of data in a small form factor. This new product supports the very latest memory cards available in today's market, SDXC (Secure Digital Extended Capacity). The SD/MicroSD/MMC Card Reader/Writer is a solution for hi-speed, bi-directional image and data transfer. Images and data can be transferred quickly from Secure Digital Card (SD), MultiMedia Card (MMC), or MicroSD memory cards to PCs or Macs.
CAD 7.69  $13.99'Not yet rated.'In StockAdd Iogear SD/MicroSD/MMC Card Reader/Writer for 12.9‑inch iPad Pro to Cart
More Memory Cards...
My 12.9‑inch iPad Pro
Shop by Category
Trending Purchases
Customer Care
Powered by...
Our Customers Say...
