12.9‑inch iPad Pro Spare Parts
Browse Spare Parts for 12.9‑inch iPad Pro
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for 12.9‑inch iPad ProweBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for 12.9‑inch iPad Pro
CAD 34.99  $45.99'Not yet rated.'Ships 1/20Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for 12.9‑inch iPad Pro to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for 12.9‑inch iPad ProweBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for 12.9‑inch iPad Pro
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for 12.9‑inch iPad Pro to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for 12.9‑inch iPad ProweBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for 12.9‑inch iPad Pro
CAD 29.99  $35.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for 12.9‑inch iPad Pro to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for 12.9‑inch iPad ProweBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for 12.9‑inch iPad Pro
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 1/20Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for 12.9‑inch iPad Pro to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for 12.9‑inch iPad ProweBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for 12.9‑inch iPad Pro
CAD 34.99  $44.99'Not yet rated.'Out of StockAdd weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for 12.9‑inch iPad Pro to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for 12.9‑inch iPad ProweBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for 12.9‑inch iPad Pro
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Ships 1/20Add weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for 12.9‑inch iPad Pro to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for 12.9‑inch iPad ProweBoost NMO Antenna 800/1900 MHz Omni Directional for 12.9‑inch iPad Pro
CAD 19.99  $26.99'Not yet rated.'Ships 1/20Add weBoost NMO Antenna 800/1900 MHz Omni Directional for 12.9‑inch iPad Pro to Cart
weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for 12.9‑inch iPad ProweBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for 12.9‑inch iPad Pro
Wilson Electronics 901101 NMO Cellular Antenna Trunk Mount with cable allows you to mount any NMO Cellular Antenna to a trunk lid or window.
CAD 13.99  $24.99'Not yet rated.'In StockAdd weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for 12.9‑inch iPad Pro to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for 12.9‑inch iPad ProweBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for 12.9‑inch iPad Pro
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for 12.9‑inch iPad Pro to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for 12.9‑inch iPad ProweBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for 12.9‑inch iPad Pro
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for 12.9‑inch iPad Pro to Cart
weBoost Marine Antenna Mount (901119) for 12.9‑inch iPad ProweBoost Marine Antenna Mount (901119) for 12.9‑inch iPad Pro
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for 12.9‑inch iPad Pro to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for 12.9‑inch iPad ProweBoost Suction Cup Window Mount for Magnet Antennas (901128) for 12.9‑inch iPad Pro
CAD 9.99  $9.99'Not yet rated.'Ships 1/20Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for 12.9‑inch iPad Pro to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for 12.9‑inch iPad ProweBoost In-Vehicle Cradle Plus Mounting Kit (901134) for 12.9‑inch iPad Pro
CAD 11.99  $14.99'Not yet rated.'Ships 1/20Add weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for 12.9‑inch iPad Pro to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for 12.9‑inch iPad ProweBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for 12.9‑inch iPad Pro
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for 12.9‑inch iPad Pro to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for 12.9‑inch iPad ProweBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for 12.9‑inch iPad Pro
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for 12.9‑inch iPad Pro to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for 12.9‑inch iPad ProweBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for 12.9‑inch iPad Pro
CAD 39.99  $49.99'Not yet rated.'Ships 1/20Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for 12.9‑inch iPad Pro to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for 12.9‑inch iPad ProweBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for 12.9‑inch iPad Pro
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 1/20Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for 12.9‑inch iPad Pro to Cart
weBoost DC 12v Hardwire Power Kit for 12.9‑inch iPad ProweBoost DC 12v Hardwire Power Kit for 12.9‑inch iPad Pro
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for 12.9‑inch iPad Pro to Cart
weBoost DC/DC 6 volt Power Supply for 12.9‑inch iPad ProweBoost DC/DC 6 volt Power Supply for 12.9‑inch iPad Pro
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for 12.9‑inch iPad Pro to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for 12.9‑inch iPad ProweBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for 12.9‑inch iPad Pro
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for 12.9‑inch iPad Pro to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for 12.9‑inch iPad ProweBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for 12.9‑inch iPad Pro
CAD 19.99  $26.99'Not yet rated.'In StockAdd weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for 12.9‑inch iPad Pro to Cart
weBoost Home Accessory Kit for Sleek Amp for 12.9‑inch iPad ProweBoost Home Accessory Kit for Sleek Amp for 12.9‑inch iPad Pro
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for 12.9‑inch iPad Pro to Cart
weBoost Battery Pack for 12.9‑inch iPad ProweBoost Battery Pack for 12.9‑inch iPad Pro
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for 12.9‑inch iPad Pro to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for 12.9‑inch iPad ProweBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for 12.9‑inch iPad Pro
CAD 35.99  $35.99'Not yet rated.'Out of StockAdd weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for 12.9‑inch iPad Pro to Cart
weBoost Adjustable Suction Cup Mount for 12.9‑inch iPad ProweBoost Adjustable Suction Cup Mount for 12.9‑inch iPad Pro
CAD 23.99  $27.99'Not yet rated.'Ships 1/20Add weBoost Adjustable Suction Cup Mount for 12.9‑inch iPad Pro to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for 12.9‑inch iPad ProweBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for 12.9‑inch iPad Pro
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for 12.9‑inch iPad Pro to Cart
weBoost 4G-X OTR Drive Kit for 12.9‑inch iPad ProweBoost 4G-X OTR Drive Kit for 12.9‑inch iPad Pro
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Pre-OrderAdd weBoost 4G-X OTR Drive Kit for 12.9‑inch iPad Pro to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for 12.9‑inch iPad ProweBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for 12.9‑inch iPad Pro
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for 12.9‑inch iPad Pro to Cart
My 12.9‑inch iPad Pro
Shop by Category
Customer Care
Powered by...
Our Customers Say...
