12.9‑inch iPad Pro Speaker Systems
Browse Speaker Systems for 12.9‑inch iPad Pro
Sort by:
Narrow By:
XMI Max Duo Speaker (Gunmetal) for 12.9‑inch iPad Pro74%XMI Max Duo Speaker (Gunmetal) for 12.9‑inch iPad Pro
The MAX offers a new standard in portable speakers with the introduction of the ceramic tweeter. The quality of sound produced from any speaker depends largely on the tweeter material and after months of research, trials and prototype development, the engineering team at Xmi Pte Ltd found that ceramic was the most suitable material to bring the X-mini™ sound to the next level. The ceramic tweeter brings about several advantages. As compared to aluminum tweeters, the ceramic ones can produce a wider frequency range covering higher and lower sounds. As a result of that, the distortion of sound is also much reduced because the ceramic tweeter is able to withstand high and low frequencies without producing any cracks in the sound.
CAD 17.99  $69.99'Not yet rated.'In StockAdd XMI Max Duo Speaker (Gunmetal) for 12.9‑inch iPad Pro to Cart
Logitech X100 Bluetooth Speaker for 12.9‑inch iPad ProLogitech X100 Bluetooth Speaker for 12.9‑inch iPad Pro
ROCKING SOUND - BUILT TO ROLL. There are times and places when you want to play and share your music out loud. This go-anywhere portable speaker has the sound quality and volume to rock the road trip or house party. Press one button to wirelessly connect the speaker to your smartphone or tablet - and you're set to rock at home or wherever you and your friends roll.
CAD 44.99  $49.99'Not yet rated.'Ships 1/25Add Logitech X100 Bluetooth Speaker for 12.9‑inch iPad Pro to Cart
ROCKING SOUND—BUILT TO ROLL. There are times and places when you want to play and share your music out loud. This go-anywhere portable speaker has the sound quality and volume to rock the road trip or house party. Press one button to wirelessly connect the speaker to your smartphone or tablet—and you’re set to rock at home or wherever you and your friends roll.
Xtreme Bluetooth Shower Speaker for 12.9‑inch iPad ProXtreme Bluetooth Shower Speaker for 12.9‑inch iPad Pro
Truly experience your music wherever you are with the Xtreme Splash Series Bluetooth Shower Speaker. You can listen to all of your favorite songs near any wet area. With its water resistance design you can be sure that water will stay out. Its bluetooth capability allows you to answer calls right from the speaker, making sure you never miss any important calls. The suction cup feature allows it to stick to virtually any surface. Enjoy your music in the Xtreme way.
CAD 16.99  $16.99'Not yet rated.'Ships 1/25Add Xtreme Bluetooth Shower Speaker for 12.9‑inch iPad Pro to Cart
CAD 16.99  $16.99'Not yet rated.'In StockAdd Xtreme Bluetooth Shower Speaker for 12.9‑inch iPad Pro to Cart
Xtreme Mini Round Bluetooth Speaker for 12.9‑inch iPad ProXtreme Mini Round Bluetooth Speaker for 12.9‑inch iPad Pro
Mini compact design with great audio quality.
CAD 16.99  $16.99'Not yet rated.'Ships 1/25Add Xtreme Mini Round Bluetooth Speaker for 12.9‑inch iPad Pro to Cart
Xtreme Durapod Rugged Weatherproof Bluetooth Speaker for 12.9‑inch iPad ProXtreme Durapod Rugged Weatherproof Bluetooth Speaker for 12.9‑inch iPad Pro
Durapod Rugged Weatherproof Bluetooth Speaker with Full Audio Control and Auxiliary Input for Non-Bluetooth Devices.
CAD 29.99  $29.99'Not yet rated.'Ships 1/25Add Xtreme Durapod Rugged Weatherproof Bluetooth Speaker for 12.9‑inch iPad Pro to Cart
My 12.9‑inch iPad Pro
Shop by Category
Customer Care
Powered by...
Our Customers Say...
