9.7‑inch iPad Pro Car Kits & Mounts
Browse Car Kits & Mounts for 9.7‑inch iPad Pro
Sort by:
Narrow By:
Jabra FREEWAY Bluetooth Car Kit for 9.7‑inch iPad ProJabra FREEWAY Bluetooth Car Kit for 9.7‑inch iPad Pro
The Jabra FREEWAY in-car speakerphone makes hands-free calls sound better than ever and makes controlling them effortless.
Free Shipping
CAD 119.99  $149.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (4)In StockView Jabra FREEWAY Bluetooth Car Kit for 9.7‑inch iPad Pro Options
Motorola TX550 SonicRider Wireless In-Car Speakerphone for 9.7‑inch iPad ProMotorola TX550 SonicRider Wireless In-Car Speakerphone for 9.7‑inch iPad Pro
Keep your hands on the wheel and your eyes on the road. SonicRider is a simple solution for hands-free, responsible driving.
CAD 49.99  $79.99Score 3.8/5Score 3.8/5Score 3.8/5Score 3.8/5Score 3.8/5 (4)In StockAdd Motorola TX550 SonicRider Wireless In-Car Speakerphone for 9.7‑inch iPad Pro to Cart
Parrot Minikit Neo 2 HD Handsfree Car Kit for 9.7‑inch iPad ProParrot Minikit Neo 2 HD Handsfree Car Kit for 9.7‑inch iPad Pro
The MINIKIT Neo 2 HD combines the best of technology in a compact and stylish design. Make and receive calls without touching any buttons and enhance your experience with the free application for Android and iPhone.
Free Shipping
CAD 99.99  $119.99'Not yet rated.'In StockAdd Parrot Minikit Neo 2 HD Handsfree Car Kit for 9.7‑inch iPad Pro to Cart
Nite Ize Steelie Vent Mount Kit for 9.7‑inch iPad ProNite Ize Steelie Vent Mount Kit for 9.7‑inch iPad Pro
The Nite Ize Steelie Vent Mount Kit is a brilliant solution for keeping your smartphone secure and visible when you're in the car. It consists of two simple components: 1) a Steelie Magnetic Phone Socket that adheres semi-permanently with 3M® VHB™ foam tape, either to the back of your case or to the phone itself, and 2) a versatile Steelie Vent Ball Mount that securely clips to most vehicle vents, and is just as easy to unclip, so it can be used in multiple vehicles. The Vent Ball's round shape allows radiant positioning options, so you can tilt your phone to any angle, and the strong magnetic attachment of the Steelie Phone Magnet Socket keeps your phone securely in place and where you need it.
CAD 49.99  $59.99'Not yet rated.'In StockAdd Nite Ize Steelie Vent Mount Kit for 9.7‑inch iPad Pro to Cart
More Car Kits & Mounts...
My 9.7‑inch iPad Pro
Shop by Category
Customer Care
Powered by...
Our Customers Say...
