9.7‑inch iPad Pro Car Mounts
Browse Car Mounts for 9.7‑inch iPad Pro
Sort by:
Narrow By:
Nite Ize Steelie Vent Mount Kit for 9.7‑inch iPad ProNite Ize Steelie Vent Mount Kit for 9.7‑inch iPad Pro
The Nite Ize Steelie Vent Mount Kit is a brilliant solution for keeping your smartphone secure and visible when you're in the car. It consists of two simple components: 1) a Steelie Magnetic Phone Socket that adheres semi-permanently with 3M® VHB™ foam tape, either to the back of your case or to the phone itself, and 2) a versatile Steelie Vent Ball Mount that securely clips to most vehicle vents, and is just as easy to unclip, so it can be used in multiple vehicles. The Vent Ball's round shape allows radiant positioning options, so you can tilt your phone to any angle, and the strong magnetic attachment of the Steelie Phone Magnet Socket keeps your phone securely in place and where you need it.
CAD 49.99  $59.99'Not yet rated.'In StockAdd Nite Ize Steelie Vent Mount Kit for 9.7‑inch iPad Pro to Cart
More Car Kits & Mounts...
My 9.7‑inch iPad Pro
Shop by Category
Trending Purchases
Customer Care
Powered by...
Our Customers Say...
