9.7‑inch iPad Pro Tools
Browse Tools for 9.7‑inch iPad Pro
Sort by:
Narrow By:
iFixit Pro Magnetic Project Mat for 9.7‑inch iPad ProiFixit Pro Magnetic Project Mat for 9.7‑inch iPad Pro
Designed by fixers, for fixers, the 8”x10” Magnetic Project Mat solves the common repair problem when you drop or misplace an important screw during your job. Spacious and secure, the mat will catch and hold screws as you pull them out of any device!
CAD 29.95  $34.99'Not yet rated.'In StockAdd iFixit Pro Magnetic Project Mat for 9.7‑inch iPad Pro to Cart
Smartphone Experts Plastic Spudger Stick Opening Repair Tool for 9.7‑inch iPad ProSmartphone Experts Plastic Spudger Stick Opening Repair Tool for 9.7‑inch iPad Pro
A spudger is a tough antistatic tool that can be used for a variety of purposes when repairing electronic devices. The 15cm tool is made of nylon and has one flat end and one pointed end.
CAD 1.95  $7.95'Not yet rated.'In StockAdd Smartphone Experts Plastic Spudger Stick Opening Repair Tool for 9.7‑inch iPad Pro to Cart
Mobi Products iSesamo Thin Pry Blade Opening Repair Tool for 9.7‑inch iPad Pro70%Mobi Products iSesamo Thin Pry Blade Opening Repair Tool for 9.7‑inch iPad Pro
Tough tool to nimbly open modern small electronic casings; Springy steel blade features a smart tip design and a handle with a great no-slip grip.
CAD 2.99  $9.99'Not yet rated.'In StockAdd Mobi Products iSesamo Thin Pry Blade Opening Repair Tool for 9.7‑inch iPad Pro to Cart
Smartphone Experts Precision Electronics Screwdriver Set for 9.7‑inch iPad Pro67%Smartphone Experts Precision Electronics Screwdriver Set for 9.7‑inch iPad Pro
This incredible value tool set contains one screwdriver handle, one bent Tweezer, one extension bar and 30 insert bits.
CAD 9.99  $29.99'Not yet rated.'In StockAdd Smartphone Experts Precision Electronics Screwdriver Set for 9.7‑inch iPad Pro to Cart
Mobi Products T2 Torx Magnetic Screwdriver (0.93mm = 0.036 in) for 9.7‑inch iPad ProMobi Products T2 Torx Magnetic Screwdriver (0.93mm = 0.036 in) for 9.7‑inch iPad Pro
Affordable T2 Torx Screw Driver ideal for mobile phone repairs. Always handy to have. Before purchasing, make sure to double check that this is the type of screwdriver you need for your type of repair/mobile phone model.
CAD 2.99  $3.99'Not yet rated.'Out of StockAdd Mobi Products T2 Torx Magnetic Screwdriver (0.93mm = 0.036 in) for 9.7‑inch iPad Pro to Cart
Mobi Products T5 Torx Magnetic Screwdriver (0.055"=1.42 mm) for 9.7‑inch iPad ProMobi Products T5 Torx Magnetic Screwdriver (0.055"=1.42 mm) for 9.7‑inch iPad Pro
Affordable T5 Torx Screw Driver ideal for mobile phone repairs. Always handy to have. Before purchasing, make sure to double check that this is the type of screwdriver you need for your type of repair/mobile phone model.
CAD 1.99  $3.99'Not yet rated.'In StockAdd Mobi Products T5 Torx Magnetic Screwdriver (0.055"=1.42 mm) for 9.7‑inch iPad Pro to Cart
Mobi Products T3 Torx Magnetic Screwdriver (0.046" = 1.10mm) for 9.7‑inch iPad ProMobi Products T3 Torx Magnetic Screwdriver (0.046" = 1.10mm) for 9.7‑inch iPad Pro
Affordable T3 Torx Screw Driver ideal for mobile phone repairs. Always handy to have. Before purchasing, make sure to double check that this is the type of screwdriver you need for your type of repair/mobile phone model.
CAD 0.99  $3.99'Not yet rated.'In StockAdd Mobi Products T3 Torx Magnetic Screwdriver (0.046" = 1.10mm) for 9.7‑inch iPad Pro to Cart
Mobi Products T6 Torx Magnetic Screwdriver (0.066" = 1.70 mm) for 9.7‑inch iPad Pro75%Mobi Products T6 Torx Magnetic Screwdriver (0.066" = 1.70 mm) for 9.7‑inch iPad Pro
Affordable T6 Torx Screw Driver ideal for mobile phone repairs. Always handy to have. Before purchasing, make sure to double check that this is the type of screwdriver you need for your type of repair/mobile phone model.
CAD 0.99  $3.99'Not yet rated.'In StockAdd Mobi Products T6 Torx Magnetic Screwdriver (0.066" = 1.70 mm) for 9.7‑inch iPad Pro to Cart
Smartphone Experts Professional Anti-Static Tweezers Kit (3-Pack) for 9.7‑inch iPad Pro62%Smartphone Experts Professional Anti-Static Tweezers Kit (3-Pack) for 9.7‑inch iPad Pro
Multi use Anti-Static Tweezers Kit
CAD 4.99  $12.99'Not yet rated.'In StockAdd Smartphone Experts Professional Anti-Static Tweezers Kit (3-Pack) for 9.7‑inch iPad Pro to Cart
iFixit Pro Tech Toolkit (IF145-307-1) for 9.7‑inch iPad ProiFixit Pro Tech Toolkit (IF145-307-1) for 9.7‑inch iPad Pro
Weve got a pulse on how electronics are held together. Armed with the data from hundreds of teardowns and thousands of repair guides, our teardown technicians were able to curate the most capable compact toolkit. And it packs a serious punch. Necessity is the mother of inventionand we invented the Pro Tech Toolkit to have the right precision tool to get you out of any tight spot.
Free Shipping
CAD 89.95  $129.99'Not yet rated.'In StockAdd iFixit Pro Tech Toolkit (IF145-307-1) for 9.7‑inch iPad Pro to Cart
WHOOSH! CleanBlast Compressed Gas Electronics Duster - 10oz for 9.7‑inch iPad ProWHOOSH! CleanBlast Compressed Gas Electronics Duster - 10oz for 9.7‑inch iPad Pro
Get rid of the dirt, dust and crumbs from your computer and laptop keyboards as well as other hard to reach areas with the WHOOSH! CleanBlast compressed gas duster. CleanBlast delivers a burst of compressed gas that effectively blasts dirt, dust and crumbs away great to use in your car, home or office.
CAD 9.99  $12.99'Not yet rated.'In StockAdd WHOOSH! CleanBlast Compressed Gas Electronics Duster - 10oz for 9.7‑inch iPad Pro to Cart
Smartphone Experts Plastic Spudger Stick Opening Repair Tool (4-pack) for 9.7‑inch iPad Pro89%Smartphone Experts Plastic Spudger Stick Opening Repair Tool (4-pack) for 9.7‑inch iPad Pro
A spudger (4-Pack) is a tough antistatic tool that can be used for a variety of purposes when repairing electronic devices. The 15cm tool is made of nylon and has one flat end and one pointed end.
CAD 3.49  $31.80'Not yet rated.'In StockAdd Smartphone Experts Plastic Spudger Stick Opening Repair Tool (4-pack) for 9.7‑inch iPad Pro to Cart
Xtreme Boost n Go Jump Starter Battery Bank for 9.7‑inch iPad ProXtreme Boost n Go Jump Starter Battery Bank for 9.7‑inch iPad Pro
The Xtreme Boost n'Go Jumper Starter charging kit is the ideal backup power source for emergency situations and power outages. Includes: 6,000mAh Battery bank, Micro USB cable and 2 jumper cables, so it can charge a wide range of electronic devices Smartphone, Laptop.., as well as jump start your car's battery. Peace of Mind-With the Xtreme Boost n'Go Jump Starter Kit, you can rest assured knowing that you can jumpstart your car or power up your electronic devices in the event of an emergency. No Stress, No Mess.
Free Shipping
CAD 59.99  $79.99'Not yet rated.'In StockAdd Xtreme Boost n Go Jump Starter Battery Bank for 9.7‑inch iPad Pro to Cart
iFixit Original Opening Tool for 9.7‑inch iPad ProiFixit Original Opening Tool for 9.7‑inch iPad Pro
Two tips provide alternate opening options: Wedge for breaching, and Hook for lifting and levering. Original iFixit Tool.
CAD 3.49'Not yet rated.'In StockAdd iFixit Original Opening Tool for 9.7‑inch iPad Pro to Cart
My 9.7‑inch iPad Pro
Shop by Category
Customer Care
Powered by...
Our Customers Say...
