iPad 2 Car Kits & Mounts
Browse Car Kits & Mounts for iPad 2
Sort by:
Narrow By:
Jabra FREEWAY Bluetooth Car Kit for iPad 2Jabra FREEWAY Bluetooth Car Kit for iPad 2
The Jabra FREEWAY in-car speakerphone makes hands-free calls sound better than ever and makes controlling them effortless.
Free Shipping
CAD 119.99  $149.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (4)In StockView Jabra FREEWAY Bluetooth Car Kit for iPad 2 Options
Motorola TX550 SonicRider Wireless In-Car Speakerphone for iPad 2Motorola TX550 SonicRider Wireless In-Car Speakerphone for iPad 2
Keep your hands on the wheel and your eyes on the road. SonicRider is a simple solution for hands-free, responsible driving.
Free Shipping
CAD 69.99  $79.99Score 3.8/5Score 3.8/5Score 3.8/5Score 3.8/5Score 3.8/5 (4)In StockAdd Motorola TX550 SonicRider Wireless In-Car Speakerphone for iPad 2 to Cart
Parrot Minikit Neo 2 HD Handsfree Car Kit for iPad 2Parrot Minikit Neo 2 HD Handsfree Car Kit for iPad 2
The MINIKIT Neo 2 HD combines the best of technology in a compact and stylish design. Make and receive calls without touching any buttons and enhance your experience with the free application for Android and iPhone.
Free Shipping
CAD 99.99  $119.99'Not yet rated.'In StockAdd Parrot Minikit Neo 2 HD Handsfree Car Kit for iPad 2 to Cart
Jabra Speak510 Wireless Bluetooth Speaker for iPad 2Jabra Speak510 Wireless Bluetooth Speaker for iPad 2
Increase productivity and stay focused wherever you are with the Jabra Speak 510, an award-winning device recognized for both sound quality and design. Enhanced with Bluetooth you can connect it to your PC, tablet or smartphone and turn any location into a conference room. Jabra Speak 510 has a compact, intuitive design and outstanding sound quality. Its convenient plug-and-play solution allows you to set up and take calls or stream multimedia within seconds. Simply connect to a mobile device via Bluetooth or to the internet using the integrated USB cable and you are ready to dial in. The high quality audio sound and 360-degree microphone enables everyone to hear and be heard from all angles across the speakerphone. But that’s not all -you can also use Jabra Speak 510 for listening to your favorite multimedia with crystal clear clarity. Jabra Speak 510 also lets you multitask while on the go, with a specially designed protective travel case that you can throw in your bag and connect when needed. Get empowered and make a difference at the office or on the go!
Free Shipping
CAD 159.99  $199.99'Not yet rated.'Ships 2/28Add Jabra Speak510 Wireless Bluetooth Speaker for iPad 2 to Cart
Nite Ize Steelie Vent Mount Kit for iPad 2Nite Ize Steelie Vent Mount Kit for iPad 2
The Nite Ize Steelie Vent Mount Kit is a brilliant solution for keeping your smartphone secure and visible when you're in the car. It consists of two simple components: 1) a Steelie Magnetic Phone Socket that adheres semi-permanently with 3M® VHB™ foam tape, either to the back of your case or to the phone itself, and 2) a versatile Steelie Vent Ball Mount that securely clips to most vehicle vents, and is just as easy to unclip, so it can be used in multiple vehicles. The Vent Ball's round shape allows radiant positioning options, so you can tilt your phone to any angle, and the strong magnetic attachment of the Steelie Phone Magnet Socket keeps your phone securely in place and where you need it.
CAD 49.99  $59.99'Not yet rated.'In StockAdd Nite Ize Steelie Vent Mount Kit for iPad 2 to Cart
More Car Kits & Mounts...
My iPad 2
Shop by Category
Customer Care
Powered by...
Our Customers Say...
