iPad 4th gen Spare Parts
Browse Spare Parts for iPad 4th gen
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPad 4th genweBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPad 4th gen
CAD 34.99  $45.99'Not yet rated.'Ships 5/8Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPad 4th gen to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPad 4th genweBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPad 4th gen
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPad 4th gen to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPad 4th genweBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPad 4th gen
CAD 29.99  $35.99'Not yet rated.'Ships 5/8Add weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPad 4th gen to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPad 4th genweBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPad 4th gen
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 5/8Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPad 4th gen to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPad 4th genweBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPad 4th gen
CAD 34.99  $44.99'Not yet rated.'Out of StockAdd weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPad 4th gen to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPad 4th genweBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPad 4th gen
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Out of StockAdd weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPad 4th gen to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for iPad 4th genweBoost NMO Antenna 800/1900 MHz Omni Directional for iPad 4th gen
CAD 19.99  $26.99'Not yet rated.'Ships 5/8Add weBoost NMO Antenna 800/1900 MHz Omni Directional for iPad 4th gen to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPad 4th genweBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPad 4th gen
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPad 4th gen to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPad 4th genweBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPad 4th gen
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPad 4th gen to Cart
weBoost Marine Antenna Mount (901119) for iPad 4th genweBoost Marine Antenna Mount (901119) for iPad 4th gen
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for iPad 4th gen to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPad 4th genweBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPad 4th gen
CAD 9.99  $9.99'Not yet rated.'Ships 5/8Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPad 4th gen to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPad 4th genweBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPad 4th gen
CAD 11.99  $14.99'Not yet rated.'In StockAdd weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPad 4th gen to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPad 4th genweBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPad 4th gen
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPad 4th gen to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPad 4th genweBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPad 4th gen
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPad 4th gen to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPad 4th genweBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPad 4th gen
CAD 39.99  $49.99'Not yet rated.'Ships 5/8Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPad 4th gen to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPad 4th genweBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPad 4th gen
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 5/8Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPad 4th gen to Cart
weBoost DC 12v Hardwire Power Kit for iPad 4th genweBoost DC 12v Hardwire Power Kit for iPad 4th gen
CAD 9.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for iPad 4th gen to Cart
weBoost DC/DC 6 volt Power Supply for iPad 4th genweBoost DC/DC 6 volt Power Supply for iPad 4th gen
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for iPad 4th gen to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPad 4th genweBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPad 4th gen
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPad 4th gen to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPad 4th genweBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPad 4th gen
CAD 19.99  $26.99'Not yet rated.'In StockView weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPad 4th gen Options
weBoost Battery Pack for iPad 4th genweBoost Battery Pack for iPad 4th gen
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for iPad 4th gen to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPad 4th genweBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPad 4th gen
CAD 35.99  $35.99'Not yet rated.'Ships 5/8Add weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPad 4th gen to Cart
weBoost Adjustable Suction Cup Mount for iPad 4th genweBoost Adjustable Suction Cup Mount for iPad 4th gen
CAD 23.99  $27.99'Not yet rated.'Ships 5/8Add weBoost Adjustable Suction Cup Mount for iPad 4th gen to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPad 4th genweBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPad 4th gen
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPad 4th gen to Cart
weBoost 4G-X OTR Drive Kit for iPad 4th genweBoost 4G-X OTR Drive Kit for iPad 4th gen
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Ships 5/8Add weBoost 4G-X OTR Drive Kit for iPad 4th gen to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPad 4th genweBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPad 4th gen
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPad 4th gen to Cart
My iPad 4th gen
Shop by Category
Customer Care
Powered by...
Our Customers Say...
