iPad Air 2 Speaker Systems
Browse Speaker Systems for iPad Air 2
Sort by:
Narrow By:
XMI Max Duo Speaker (Gunmetal) for iPad Air 271%XMI Max Duo Speaker (Gunmetal) for iPad Air 2
The MAX offers a new standard in portable speakers with the introduction of the ceramic tweeter. The quality of sound produced from any speaker depends largely on the tweeter material and after months of research, trials and prototype development, the engineering team at Xmi Pte Ltd found that ceramic was the most suitable material to bring the X-mini™ sound to the next level. The ceramic tweeter brings about several advantages. As compared to aluminum tweeters, the ceramic ones can produce a wider frequency range covering higher and lower sounds. As a result of that, the distortion of sound is also much reduced because the ceramic tweeter is able to withstand high and low frequencies without producing any cracks in the sound.
CAD 19.99  $69.99'Not yet rated.'In StockAdd XMI Max Duo Speaker (Gunmetal) for iPad Air 2 to Cart
Logitech X100 Bluetooth Speaker for iPad Air 2Logitech X100 Bluetooth Speaker for iPad Air 2
ROCKING SOUND - BUILT TO ROLL. There are times and places when you want to play and share your music out loud. This go-anywhere portable speaker has the sound quality and volume to rock the road trip or house party. Press one button to wirelessly connect the speaker to your smartphone or tablet - and you're set to rock at home or wherever you and your friends roll.
CAD 44.99  $49.99'Not yet rated.'Pre-OrderAdd Logitech X100 Bluetooth Speaker for iPad Air 2 to Cart
ROCKING SOUND—BUILT TO ROLL. There are times and places when you want to play and share your music out loud. This go-anywhere portable speaker has the sound quality and volume to rock the road trip or house party. Press one button to wirelessly connect the speaker to your smartphone or tablet—and you’re set to rock at home or wherever you and your friends roll.
CAD 44.99  $49.99'Not yet rated.'Ships 2/24Add Logitech X100 Bluetooth Speaker for iPad Air 2 to Cart
Xtreme Bluetooth Shower Speaker for iPad Air 2Xtreme Bluetooth Shower Speaker for iPad Air 2
Truly experience your music wherever you are with the Xtreme Splash Series Bluetooth Shower Speaker. You can listen to all of your favorite songs near any wet area. With its water resistance design you can be sure that water will stay out. Its bluetooth capability allows you to answer calls right from the speaker, making sure you never miss any important calls. The suction cup feature allows it to stick to virtually any surface. Enjoy your music in the Xtreme way.
CAD 16.99  $16.99'Not yet rated.'Ships 2/24Add Xtreme Bluetooth Shower Speaker for iPad Air 2 to Cart
CAD 16.99  $16.99'Not yet rated.'In StockAdd Xtreme Bluetooth Shower Speaker for iPad Air 2 to Cart
Xtreme Mini Round Bluetooth Speaker for iPad Air 2Xtreme Mini Round Bluetooth Speaker for iPad Air 2
Mini compact design with great audio quality.
CAD 16.99  $16.99'Not yet rated.'Out of StockAdd Xtreme Mini Round Bluetooth Speaker for iPad Air 2 to Cart
Xtreme Durapod Rugged Weatherproof Bluetooth Speaker for iPad Air 2Xtreme Durapod Rugged Weatherproof Bluetooth Speaker for iPad Air 2
Durapod Rugged Weatherproof Bluetooth Speaker with Full Audio Control and Auxiliary Input for Non-Bluetooth Devices.
CAD 29.99  $29.99'Not yet rated.'Ships 2/24Add Xtreme Durapod Rugged Weatherproof Bluetooth Speaker for iPad Air 2 to Cart
My iPad Air 2
Shop by Category
Trending Purchases
Customer Care
Powered by...
Our Customers Say...
