iPad Air USB Cables
Browse USB Cables for iPad Air
Sort by:
Narrow By:
Apple Original Lightning to USB Cable for iPad AirApple Original Lightning to USB Cable for iPad Air
This Apple USB 2.0 cable connects your iPad Air to your computer's USB port for syncing and charging or to the Apple USB Power Adapter for convenient charging from a wall outlet.
Free Shipping
CAD 14.99  $21.00Score 4/5Score 4/5Score 4/5Score 4/5Score 4/5 (14)In StockAdd Apple Original Lightning to USB Cable for iPad Air to Cart
Plantronics Voyager Legend Charge Cable for iPad AirPlantronics Voyager Legend Charge Cable for iPad Air
This spare, 9-inch USB charge cable is ideal for recharging your Plantronics Voyager Legend headset from your laptop’s USB port.
CAD 11.99  $24.95'Not yet rated.'Out of StockAdd Plantronics Voyager Legend Charge Cable for iPad Air to Cart
Belkin USB Extender Cable for iPad AirBelkin USB Extender Cable for iPad Air
The Pro Series USB Extension Cable extends the length of your USB device cable to your hub, PC, or Mac. Perfect for devices with short cables. Molded strain relief and PVC overmolding to ensure a lifetime of error-free data transmissions.
Free Shipping
CAD 6.99  $9.99'Not yet rated.'In StockAdd Belkin USB Extender Cable for iPad Air to Cart
puregear Flat USB Lightning Cable 4 Ft (Black) for iPad Airpuregear Flat USB Lightning Cable 4 Ft (Black) for iPad Air
Flat charge-sync cable for Lightning USB devices - 4 Ft.
CAD 19.99  $29.99'Not yet rated.'In StockAdd puregear Flat USB Lightning Cable 4 Ft (Black) for iPad Air to Cart
MYBAT Woven Pattern Data Lightning to USB Cable - 6 FT (Black) for iPad Air55%MYBAT Woven Pattern Data Lightning to USB Cable - 6 FT (Black) for iPad Air
Woven, extra strong 6 Feet Long Lightning to USB Cable.
CAD 8.99  $19.99Score 3/5Score 3/5Score 3/5Score 3/5Score 3/5 (2)In StockAdd MYBAT Woven Pattern Data Lightning to USB Cable - 6 FT (Black) for iPad Air to Cart
MYBAT Micro USB to 8 Pin Lightning Adapter for iPad Air60%MYBAT Micro USB to 8 Pin Lightning Adapter for iPad Air
Did you switch from an Android device to a new iPhone iPad? Do you have a lot of micro USB chargers laying around? The Micro USB to Lightning Adapter allows you to use a micro USB charger to sync and charge your iPhone or iPad.
CAD 3.99  $9.99'Not yet rated.'Out of StockAdd MYBAT Micro USB to 8 Pin Lightning Adapter for iPad Air to Cart
iQ 2 in 1 Apple Lightning and Micro-USB Charge and Sync Cable (1 Meter) for iPad AiriQ 2 in 1 Apple Lightning and Micro-USB Charge and Sync Cable (1 Meter) for iPad Air
Charging or syncing is easy with this 2 in 1 Apple Lightning and Micro-USB cable.
CAD 19.99  $24.99'Not yet rated.'In StockAdd iQ 2 in 1 Apple Lightning and Micro-USB Charge and Sync Cable (1 Meter) for iPad Air to Cart
Visiontek Lightning 0.25m Apple approved Cable - Black for iPad AirVisiontek Lightning 0.25m Apple approved Cable - Black for iPad Air
The VisionTek Lightning to USB 3.0/2.0 Charge & Sync Cable helps you make a reliable and affordable connection to Apple Lightning mobile iDevices.
CAD 9.99  $24.99'Not yet rated.'Ships 4/28Add Visiontek Lightning 0.25m Apple approved Cable - Black for iPad Air to Cart
MYBAT Noodle SYNC CABLE for Lightning (Black) for iPad AirMYBAT Noodle SYNC CABLE for Lightning (Black) for iPad Air
This MYBAT Noodle SYNC CABLE for Lightning (Black) connects your iPad Air to your computer's USB port for syncing and charging.
CAD 5.99  $19.99'Not yet rated.'In StockAdd MYBAT Noodle SYNC CABLE for Lightning (Black) for iPad Air to Cart
Digital Treasures 3 for iPad AirDigital Treasures 3 for iPad Air
Extra Strong Apple Approved Charge And Sync 3' Lightning Cable
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd Digital Treasures 3 for iPad Air to Cart
Apple 2m OEM Lightning-to-USB 2.0 Cable - White for iPad Air43%Apple 2m OEM Lightning-to-USB 2.0 Cable - White for iPad Air
Connect your compatible Apple device to your computer's USB port with this Apple MD819ZM/A cable which features a Lightning connector to help charge and sync your iPad Air
CAD 19.99  $35.00'Not yet rated.'In StockAdd Apple 2m OEM Lightning-to-USB 2.0 Cable - White for iPad Air to Cart
Seidio Lightning USB Cable (2.0m) for iPad AirSeidio Lightning USB Cable (2.0m) for iPad Air
The Lightning Cable (2.0m) with high connectivity is a great way to keep your iPad Air or iPad charged and updated for use.
CAD 19.95  $29.95'Not yet rated.'Out of StockAdd Seidio Lightning USB Cable (2.0m) for iPad Air to Cart
Mobi Products USB Data Lightning Cable - 1m for iPad Air85%Mobi Products USB Data Lightning Cable - 1m for iPad Air
CAD 2.99  $19.99'Not yet rated.'In StockView Mobi Products USB Data Lightning Cable - 1m for iPad Air Options
puregear Charge/Sync Cable Lightning 6ft (Black) for iPad Airpuregear Charge/Sync Cable Lightning 6ft (Black) for iPad Air
Keep your Apple devices completely charged and all of your data synced whether you're at home or on the go with a PureGear Lightning Cable. This cable features low-profile connectors and a discreet black jacket promising high-performance and a sleek look for design-conscious users.
CAD 19.99  $24.99'Not yet rated.'Out of StockAdd puregear Charge/Sync Cable Lightning 6ft (Black) for iPad Air to Cart
Bluelounge CableDrop for iPad AirBluelounge CableDrop for iPad Air
CableDrops put an end to the insanity of chasing that cable that seems to slip and disappear behind every flat surface, day after day.
CAD 9.99  $14.99'Not yet rated.'In StockAdd Bluelounge CableDrop for iPad Air to Cart
Bluelounge CableDrop Mini for iPad AirBluelounge CableDrop Mini for iPad Air
CAD 9.99  $14.99'Not yet rated.'In StockAdd Bluelounge CableDrop Mini for iPad Air to Cart
Visiontek 1 Meter Apple Lightning to USB (Apple Approved) for iPad Air60%Visiontek 1 Meter Apple Lightning to USB (Apple Approved) for iPad Air
The VisionTek Lightning to USB 3.0/2.0 Charge & Sync Cable helps you make a reliable and affordable connection to a wide variety of Apple mobile devices. With full compatibility with iOS 7, you'll enjoy error-free use while connecting to a Mac or PC's USB port for charging and data syncing. With various cable lengths available, this handy cable offers device placement flexibility. Don't get caught not being able to charge in the car or office... this cable makes it the affordable spare cable solution.
CAD 9.99  $24.99'Not yet rated.'In StockAdd Visiontek 1 Meter Apple Lightning to USB (Apple Approved) for iPad Air to Cart
StarTech.com 3m (10ft) Long Apple 8-pin Lightning Connector to USB Cable for iPad AirStarTech.com 3m (10ft) Long Apple 8-pin Lightning Connector to USB Cable for iPad Air
Charge and Sync your Apple Lightning-equipped devices over longer distances - The USBLT3MB 10ft/3m Black Lightning to USB Cable for iPhone, iPod and iPad is colored to suit your black mobile devices and enables long-range syncing and charging of your Lightning-enabled mobile digital devices - making it ideal for people on the move who need to access their device while it's charging. The cable features heavy gauge (20 AWG) wire for overcoming distance restrictions and allowing for full charging power at a distance of up to 3m, with no loss of charge time. The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device. This durable cable is compliant with Apple MFi Standards and is backed StarTech.com's 2-year Warranty to ensure dependable performance.
CAD 36.99  $39.99'Not yet rated.'Out of StockAdd StarTech.com 3m (10ft) Long Apple 8-pin Lightning Connector to USB Cable for iPad Air to Cart
StarTech.com 3m (10ft) Long Apple 8-pin Lightning Connector to USB Cable (Apple Approved) for iPad AirStarTech.com 3m (10ft) Long Apple 8-pin Lightning Connector to USB Cable (Apple Approved) for iPad Air
Charge and Sync your Apple Lightning-equipped devices over longer distances - The USBLT3MW 10ft/3m White Lightning to USB Cable for iPhone, iPod and iPad is colored to suit your white mobile devices and enables long-range syncing and charging of your Lightning-enabled mobile digital devices - making it ideal for people on the move who need to access their device while it's charging. The cable features heavy gauge (20 AWG) wire for overcoming distance restrictions and allowing for full charging power at a distance of up to 3m, with no loss of charge time. The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device. This durable cable is compliant with Apple MFi Standards and is backed StarTech.com's 2-year Warranty to ensure dependable performance.
CAD 36.99  $39.99'Not yet rated.'Pre-OrderAdd StarTech.com 3m (10ft) Long Apple 8-pin Lightning Connector to USB Cable (Apple Approved) for iPad Air to Cart
StarTech.com 0.3m (1ft) Coiled Apple 8-pin Lightning Connector to USB Cable for iPad Air53%StarTech.com 0.3m (1ft) Coiled Apple 8-pin Lightning Connector to USB Cable for iPad Air
The USBCLT30CMB Black Coiled Lightning to USB Cable for iPhone, iPod, and iPad can comfortably be stretched out to up to 0.3m/1ft to reach your mobile device and when compressed can be tucked out of way, to provide simple, tidy connections – great for charging in your car (requires USB charge port).
CAD 18.99  $39.99'Not yet rated.'Ships 4/28Add StarTech.com 0.3m (1ft) Coiled Apple 8-pin Lightning Connector to USB Cable for iPad Air to Cart
StarTech.com Angled Lightning to USB Cable - 2m (6ft) (Apple Approved) for iPad AirStarTech.com Angled Lightning to USB Cable - 2m (6ft) (Apple Approved) for iPad Air
This 2-meter (6-foot) angled lightning cable is great for connecting your mounted mobile devices. You can position it as needed to accommodate your fixed-in-place iPad or iPhone. charge and sync your mounted devices wherever your iPad or iPhone is mounted, this cable provides the flexibility to suit your installation. With an angled lightning connector, you can position the cable to the left or right of your mobile device in either portrait or landscape mode, without having to worry about straining the connection port. charge your device from further away at two meters (six feet) in length, this convenient cable provides full charging power even at a longer connection distance than most. So, you won't have to endure slow charge times, even when your iPad or iPhone is mounted to a desk, a wall or in your car. access your device while it's charging the angled connector positions the cable in such a way that it's easy to access your iPad or iPhone in either portrait or landscape mode, even while charging. Now, you can text, work or game without the cable getting in the way. the usblt2mwr lightning cable is apple MFi certified and backed by StarTech.com's 2-Year warranty.
CAD 26.99  $39.99'Not yet rated.'Ships 4/28Add StarTech.com Angled Lightning to USB Cable - 2m (6ft) (Apple Approved) for iPad Air to Cart
Bluelounge Cabledrop Bright for iPad AirBluelounge Cabledrop Bright for iPad Air
CableDrops are little drops that grasp peripheral cables to keep them in place, routed and within reach wherever you may need them.
CAD 11.99  $14.99'Not yet rated.'In StockAdd Bluelounge Cabledrop Bright for iPad Air to Cart
Visiontek Lightning to USB 1 Meter Cable (Apple Approved) for iPad AirVisiontek Lightning to USB 1 Meter Cable (Apple Approved) for iPad Air
The VisionTek Lightning to USB 3.0/2.0 Charge & Sync Cable helps you make a reliable and affordable connection to a wide variety of Apple mobile iDevices. With full compatibility with iOS 7, you'll enjoy error-free use while connecting to a Mac or PC's USB port for charging and data syncing. At over three feet in length, this handy cable offers device placement flexibility. Don't get caught not being able to charge in the car or office... this cable makes it the affordable spare cable solution.
CAD 8.99  $19.99'Not yet rated.'In StockAdd Visiontek Lightning to USB 1 Meter Cable (Apple Approved) for iPad Air to Cart
Visiontek Micro USB to Lightning Tip Adapter 3 Pack for iPad AirVisiontek Micro USB to Lightning Tip Adapter 3 Pack for iPad Air
The VisionTek Micro USB to Lightning Tip Adapter converts a male micro USB connection to a male Lightning connection. This handy little adapter allows you to make use of micro USB based cables in a Apple environment. With full compatibility with iOS 7 or later, you'll enjoy error-free use while connecting to a Mac or PC's USB port for charging and data syncing. Micro USB is a popular standard on Android based devices including many Samsung phones and tablets. With full compatibility with iOS 7 or later, you'll enjoy error-free use while connecting to a Mac or PC's USB port for charging and data syncing. Don't get caught not being able to charge your Apple based Lightning device because you have the wrong cable... this adapter is the affordable perfect solution. Ideal for families that have multiple types of phones/tablets. 3 tips included per pack.
CAD 12.99  $19.99'Not yet rated.'Ships 4/28Add Visiontek Micro USB to Lightning Tip Adapter 3 Pack for iPad Air to Cart
Visiontek Lightning to USB .25 Meter Cable (Apple Approved) for iPad Air50%Visiontek Lightning to USB .25 Meter Cable (Apple Approved) for iPad Air
CAD 9.99  $19.99'Not yet rated.'Ships 4/28Add Visiontek Lightning to USB .25 Meter Cable (Apple Approved) for iPad Air to Cart
Griffin Technology 9.8 ft Lightning/USB Data Transfer Cable for iPad AirGriffin Technology 9.8 ft Lightning/USB Data Transfer Cable for iPad Air
Our Lightning Connector cable is almost 10-Feet long and built with heavy-duty 20-gauge conductors to handle the 10 watt power needs of Apple's iPad. Connect this cable to your computer's USB port to sync your iPad, iPod, or iPhone; or to any 10 watt USB power source (we suggest our own PowerBlock or PowerJolt) and charge from 10-Feet away.
CAD 19.99  $26.99'Not yet rated.'Pre-OrderAdd Griffin Technology 9.8 ft Lightning/USB Data Transfer Cable for iPad Air to Cart
StarTech.com 3-Feet 8-Pin Lightning to USB Charge Sync Cable for iPad Air43%StarTech.com 3-Feet 8-Pin Lightning to USB Charge Sync Cable for iPad Air
Charge And Sync Your Apple Lightning-Equipped Devices - The 3-Feet 8-Pin Lightning to USB Cable.
CAD 19.99  $34.99'Not yet rated.'Ships 4/28Add StarTech.com 3-Feet 8-Pin Lightning to USB Charge Sync Cable for iPad Air to Cart
My iPad Air
Shop by Category
Customer Care
Powered by...
Our Customers Say...
