iPad mini 3 Spare Parts
Browse Spare Parts for iPad mini 3
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPad mini 3weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPad mini 3
CAD 34.99  $45.99'Not yet rated.'Ships 1/21Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPad mini 3 to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPad mini 3weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPad mini 3
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPad mini 3 to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPad mini 3weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPad mini 3
CAD 29.99  $35.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPad mini 3 to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPad mini 3weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPad mini 3
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 1/21Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPad mini 3 to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPad mini 3weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPad mini 3
CAD 34.99  $44.99'Not yet rated.'Out of StockAdd weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPad mini 3 to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPad mini 3weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPad mini 3
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Ships 1/21Add weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPad mini 3 to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for iPad mini 3weBoost NMO Antenna 800/1900 MHz Omni Directional for iPad mini 3
CAD 19.99  $26.99'Not yet rated.'Ships 1/21Add weBoost NMO Antenna 800/1900 MHz Omni Directional for iPad mini 3 to Cart
weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPad mini 3weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPad mini 3
Wilson Electronics 901101 NMO Cellular Antenna Trunk Mount with cable allows you to mount any NMO Cellular Antenna to a trunk lid or window.
CAD 13.99  $24.99'Not yet rated.'In StockAdd weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPad mini 3 to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPad mini 3weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPad mini 3
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPad mini 3 to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPad mini 3weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPad mini 3
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPad mini 3 to Cart
weBoost Marine Antenna Mount (901119) for iPad mini 3weBoost Marine Antenna Mount (901119) for iPad mini 3
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for iPad mini 3 to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPad mini 3weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPad mini 3
CAD 9.99  $9.99'Not yet rated.'Ships 1/21Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPad mini 3 to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPad mini 3weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPad mini 3
CAD 11.99  $14.99'Not yet rated.'Ships 1/21Add weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPad mini 3 to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPad mini 3weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPad mini 3
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPad mini 3 to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPad mini 3weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPad mini 3
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPad mini 3 to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPad mini 3weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPad mini 3
CAD 39.99  $49.99'Not yet rated.'Ships 1/21Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPad mini 3 to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPad mini 3weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPad mini 3
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 1/21Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPad mini 3 to Cart
weBoost DC 12v Hardwire Power Kit for iPad mini 3weBoost DC 12v Hardwire Power Kit for iPad mini 3
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for iPad mini 3 to Cart
weBoost DC/DC 6 volt Power Supply for iPad mini 3weBoost DC/DC 6 volt Power Supply for iPad mini 3
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for iPad mini 3 to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPad mini 3weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPad mini 3
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPad mini 3 to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPad mini 3weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPad mini 3
CAD 19.99  $26.99'Not yet rated.'In StockAdd weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPad mini 3 to Cart
weBoost Home Accessory Kit for Sleek Amp for iPad mini 3weBoost Home Accessory Kit for Sleek Amp for iPad mini 3
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for iPad mini 3 to Cart
weBoost Battery Pack for iPad mini 3weBoost Battery Pack for iPad mini 3
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for iPad mini 3 to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPad mini 3weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPad mini 3
CAD 35.99  $35.99'Not yet rated.'Out of StockAdd weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPad mini 3 to Cart
weBoost Adjustable Suction Cup Mount for iPad mini 3weBoost Adjustable Suction Cup Mount for iPad mini 3
CAD 23.99  $27.99'Not yet rated.'Ships 1/21Add weBoost Adjustable Suction Cup Mount for iPad mini 3 to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPad mini 3weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPad mini 3
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPad mini 3 to Cart
weBoost 4G-X OTR Drive Kit for iPad mini 3weBoost 4G-X OTR Drive Kit for iPad mini 3
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Pre-OrderAdd weBoost 4G-X OTR Drive Kit for iPad mini 3 to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPad mini 3weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPad mini 3
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPad mini 3 to Cart
My iPad mini 3
Shop by Category
Customer Care
Powered by...
Our Customers Say...
