iPad mini 3 USB Cables
Browse USB Cables for iPad mini 3
Sort by:
Narrow By:
Apple Original Lightning to USB Cable for iPad mini 3Apple Original Lightning to USB Cable for iPad mini 3
This Apple USB 2.0 cable connects your iPad mini 3 to your computer's USB port for syncing and charging or to the Apple USB Power Adapter for convenient charging from a wall outlet.
Free Shipping
CAD 12.99  $21.00Score 4.2/5Score 4.2/5Score 4.2/5Score 4.2/5Score 4.2/5 (12)In StockAdd Apple Original Lightning to USB Cable for iPad mini 3 to Cart
Plantronics Voyager Legend Charge Cable for iPad mini 3Plantronics Voyager Legend Charge Cable for iPad mini 3
This spare, 9-inch USB charge cable is ideal for recharging your Plantronics Voyager Legend headset from your laptop’s USB port.
CAD 11.99  $24.95'Not yet rated.'In StockAdd Plantronics Voyager Legend Charge Cable for iPad mini 3 to Cart
Belkin USB Extender Cable for iPad mini 3Belkin USB Extender Cable for iPad mini 3
The Pro Series USB Extension Cable extends the length of your USB device cable to your hub, PC, or Mac. Perfect for devices with short cables. Molded strain relief and PVC overmolding to ensure a lifetime of error-free data transmissions.
Free Shipping
CAD 6.99  $9.99'Not yet rated.'In StockAdd Belkin USB Extender Cable for iPad mini 3 to Cart
puregear Flat USB Lightning Cable 4 Ft (Black) for iPad mini 3puregear Flat USB Lightning Cable 4 Ft (Black) for iPad mini 3
Flat charge-sync cable for Lightning USB devices - 4 Ft.
CAD 19.99  $29.99'Not yet rated.'In StockAdd puregear Flat USB Lightning Cable 4 Ft (Black) for iPad mini 3 to Cart
MYBAT Woven Pattern Data Lightning to USB Cable - 6 FT (Black) for iPad mini 355%MYBAT Woven Pattern Data Lightning to USB Cable - 6 FT (Black) for iPad mini 3
Woven, extra strong 6 Feet Long Lightning to USB Cable.
CAD 8.99  $19.99Score 3/5Score 3/5Score 3/5Score 3/5Score 3/5 (2)Ships 1/24Add MYBAT Woven Pattern Data Lightning to USB Cable - 6 FT (Black) for iPad mini 3 to Cart
MYBAT Micro USB to 8 Pin Lightning Adapter for iPad mini 360%MYBAT Micro USB to 8 Pin Lightning Adapter for iPad mini 3
Did you switch from an Android device to a new iPhone iPad? Do you have a lot of micro USB chargers laying around? The Micro USB to Lightning Adapter allows you to use a micro USB charger to sync and charge your iPhone or iPad.
CAD 3.99  $9.99'Not yet rated.'Out of StockAdd MYBAT Micro USB to 8 Pin Lightning Adapter for iPad mini 3 to Cart
iQ 2 in 1 Apple Lightning and Micro-USB Charge and Synch Cable (1 Meter) for iPad mini 3iQ 2 in 1 Apple Lightning and Micro-USB Charge and Synch Cable (1 Meter) for iPad mini 3
Charging or syncing is easy with this 2 in 1 Apple Lightning and Micro-USB cable.
CAD 19.99  $24.99'Not yet rated.'In StockAdd iQ 2 in 1 Apple Lightning and Micro-USB Charge and Synch Cable (1 Meter) for iPad mini 3 to Cart
Visiontek Lightning 0.25m Apple approved Cable - Black for iPad mini 3Visiontek Lightning 0.25m Apple approved Cable - Black for iPad mini 3
The VisionTek Lightning to USB 3.0/2.0 Charge & Sync Cable helps you make a reliable and affordable connection to Apple Lightning mobile iDevices.
CAD 9.99  $24.99'Not yet rated.'Out of StockAdd Visiontek Lightning 0.25m Apple approved Cable - Black for iPad mini 3 to Cart
MYBAT Noodle SYNC CABLE for Lightning (Black) for iPad mini 3MYBAT Noodle SYNC CABLE for Lightning (Black) for iPad mini 3
This MYBAT Noodle SYNC CABLE for Lightning (Black) connects your iPad mini 3 to your computer's USB port for syncing and charging.
CAD 5.99  $19.99'Not yet rated.'Ships 1/24Add MYBAT Noodle SYNC CABLE for Lightning (Black) for iPad mini 3 to Cart
Digital Treasures 3 for iPad mini 3Digital Treasures 3 for iPad mini 3
Extra Strong Apple Approved Charge And Sync 3' Lightning Cable
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd Digital Treasures 3 for iPad mini 3 to Cart
Apple 2m OEM Lightning-to-USB 2.0 Cable - White for iPad mini 3Apple 2m OEM Lightning-to-USB 2.0 Cable - White for iPad mini 3
Connect your compatible Apple device to your computer's USB port with this Apple MD819ZM/A cable which features a Lightning connector to help charge and sync your iPad mini 3
CAD 26.99  $35.00'Not yet rated.'In StockAdd Apple 2m OEM Lightning-to-USB 2.0 Cable - White for iPad mini 3 to Cart
Seidio Lightning USB Cable (2.0m) for iPad mini 3Seidio Lightning USB Cable (2.0m) for iPad mini 3
The Lightning Cable (2.0m) with high connectivity is a great way to keep your iPad mini 3 or iPad charged and updated for use.
CAD 19.95  $29.95'Not yet rated.'In StockAdd Seidio Lightning USB Cable (2.0m) for iPad mini 3 to Cart
Mobi Products USB Data Lightning Cable - 1m for iPad mini 385%Mobi Products USB Data Lightning Cable - 1m for iPad mini 3
CAD 2.99  $19.99'Not yet rated.'In StockView Mobi Products USB Data Lightning Cable - 1m for iPad mini 3 Options
puregear Charge/Sync Cable Lightning 6ft (Black) for iPad mini 3puregear Charge/Sync Cable Lightning 6ft (Black) for iPad mini 3
Keep your Apple devices completely charged and all of your data synced whether you're at home or on the go with a PureGear Lightning Cable. This cable features low-profile connectors and a discreet black jacket promising high-performance and a sleek look for design-conscious users.
CAD 19.99  $24.99'Not yet rated.'Out of StockAdd puregear Charge/Sync Cable Lightning 6ft (Black) for iPad mini 3 to Cart
Bluelounge CableDrop for iPad mini 3Bluelounge CableDrop for iPad mini 3
CableDrops put an end to the insanity of chasing that cable that seems to slip and disappear behind every flat surface, day after day.
CAD 9.99  $14.99'Not yet rated.'In StockAdd Bluelounge CableDrop for iPad mini 3 to Cart
Bluelounge CableDrop Mini for iPad mini 3Bluelounge CableDrop Mini for iPad mini 3
CAD 9.99  $14.99'Not yet rated.'In StockAdd Bluelounge CableDrop Mini for iPad mini 3 to Cart
Visiontek 1 Meter Apple Lightning to USB (Apple Approved) for iPad mini 360%Visiontek 1 Meter Apple Lightning to USB (Apple Approved) for iPad mini 3
The VisionTek Lightning to USB 3.0/2.0 Charge & Sync Cable helps you make a reliable and affordable connection to a wide variety of Apple mobile devices. With full compatibility with iOS 7, you'll enjoy error-free use while connecting to a Mac or PC's USB port for charging and data syncing. With various cable lengths available, this handy cable offers device placement flexibility. Don't get caught not being able to charge in the car or office... this cable makes it the affordable spare cable solution.
CAD 9.99  $24.99'Not yet rated.'In StockAdd Visiontek 1 Meter Apple Lightning to USB (Apple Approved) for iPad mini 3 to Cart
StarTech.com 3m (10ft) Long Apple 8-pin Lightning Connector to USB Cable for iPad mini 3StarTech.com 3m (10ft) Long Apple 8-pin Lightning Connector to USB Cable for iPad mini 3
Charge and Sync your Apple Lightning-equipped devices over longer distances - The USBLT3MB 10ft/3m Black Lightning to USB Cable for iPhone, iPod and iPad is colored to suit your black mobile devices and enables long-range syncing and charging of your Lightning-enabled mobile digital devices - making it ideal for people on the move who need to access their device while it's charging. The cable features heavy gauge (20 AWG) wire for overcoming distance restrictions and allowing for full charging power at a distance of up to 3m, with no loss of charge time. The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device. This durable cable is compliant with Apple MFi Standards and is backed StarTech.com's 2-year Warranty to ensure dependable performance.
CAD 36.99  $39.99'Not yet rated.'Out of StockAdd StarTech.com 3m (10ft) Long Apple 8-pin Lightning Connector to USB Cable for iPad mini 3 to Cart
StarTech.com 3m (10ft) Long Apple 8-pin Lightning Connector to USB Cable (Apple Approved) for iPad mini 3StarTech.com 3m (10ft) Long Apple 8-pin Lightning Connector to USB Cable (Apple Approved) for iPad mini 3
Charge and Sync your Apple Lightning-equipped devices over longer distances - The USBLT3MW 10ft/3m White Lightning to USB Cable for iPhone, iPod and iPad is colored to suit your white mobile devices and enables long-range syncing and charging of your Lightning-enabled mobile digital devices - making it ideal for people on the move who need to access their device while it's charging. The cable features heavy gauge (20 AWG) wire for overcoming distance restrictions and allowing for full charging power at a distance of up to 3m, with no loss of charge time. The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device. This durable cable is compliant with Apple MFi Standards and is backed StarTech.com's 2-year Warranty to ensure dependable performance.
CAD 36.99  $39.99'Not yet rated.'Pre-OrderAdd StarTech.com 3m (10ft) Long Apple 8-pin Lightning Connector to USB Cable (Apple Approved) for iPad mini 3 to Cart
StarTech.com 0.3m (1ft) Coiled Apple 8-pin Lightning Connector to USB Cable for iPad mini 353%StarTech.com 0.3m (1ft) Coiled Apple 8-pin Lightning Connector to USB Cable for iPad mini 3
The USBCLT30CMB Black Coiled Lightning to USB Cable for iPhone, iPod, and iPad can comfortably be stretched out to up to 0.3m/1ft to reach your mobile device and when compressed can be tucked out of way, to provide simple, tidy connections – great for charging in your car (requires USB charge port).
CAD 18.99  $39.99'Not yet rated.'Ships 1/24Add StarTech.com 0.3m (1ft) Coiled Apple 8-pin Lightning Connector to USB Cable for iPad mini 3 to Cart
StarTech.com Angled Lightning to USB Cable - 2m (6ft) (Apple Approved) for iPad mini 3StarTech.com Angled Lightning to USB Cable - 2m (6ft) (Apple Approved) for iPad mini 3
This 2-meter (6-foot) angled lightning cable is great for connecting your mounted mobile devices. You can position it as needed to accommodate your fixed-in-place iPad or iPhone. charge and sync your mounted devices wherever your iPad or iPhone is mounted, this cable provides the flexibility to suit your installation. With an angled lightning connector, you can position the cable to the left or right of your mobile device in either portrait or landscape mode, without having to worry about straining the connection port. charge your device from further away at two meters (six feet) in length, this convenient cable provides full charging power even at a longer connection distance than most. So, you won't have to endure slow charge times, even when your iPad or iPhone is mounted to a desk, a wall or in your car. access your device while it's charging the angled connector positions the cable in such a way that it's easy to access your iPad or iPhone in either portrait or landscape mode, even while charging. Now, you can text, work or game without the cable getting in the way. the usblt2mwr lightning cable is apple MFi certified and backed by StarTech.com's 2-Year warranty.
CAD 26.99  $39.99'Not yet rated.'Ships 1/24Add StarTech.com Angled Lightning to USB Cable - 2m (6ft) (Apple Approved) for iPad mini 3 to Cart
Bluelounge Cabledrop Bright for iPad mini 3Bluelounge Cabledrop Bright for iPad mini 3
CableDrops are little drops that grasp peripheral cables to keep them in place, routed and within reach wherever you may need them.
CAD 11.99  $14.99'Not yet rated.'In StockAdd Bluelounge Cabledrop Bright for iPad mini 3 to Cart
Visiontek Lightning to USB 1 Meter Cable (Apple Approved) for iPad mini 3Visiontek Lightning to USB 1 Meter Cable (Apple Approved) for iPad mini 3
The VisionTek Lightning to USB 3.0/2.0 Charge & Sync Cable helps you make a reliable and affordable connection to a wide variety of Apple mobile iDevices. With full compatibility with iOS 7, you'll enjoy error-free use while connecting to a Mac or PC's USB port for charging and data syncing. At over three feet in length, this handy cable offers device placement flexibility. Don't get caught not being able to charge in the car or office... this cable makes it the affordable spare cable solution.
CAD 8.99  $19.99'Not yet rated.'In StockAdd Visiontek Lightning to USB 1 Meter Cable (Apple Approved) for iPad mini 3 to Cart
Visiontek Micro USB to Lightning Tip Adapter 3 Pack for iPad mini 340%Visiontek Micro USB to Lightning Tip Adapter 3 Pack for iPad mini 3
The VisionTek Micro USB to Lightning Tip Adapter converts a male micro USB connection to a male Lightning connection. This handy little adapter allows you to make use of micro USB based cables in a Apple environment. With full compatibility with iOS 7 or later, you'll enjoy error-free use while connecting to a Mac or PC's USB port for charging and data syncing. Micro USB is a popular standard on Android based devices including many Samsung phones and tablets. With full compatibility with iOS 7 or later, you'll enjoy error-free use while connecting to a Mac or PC's USB port for charging and data syncing. Don't get caught not being able to charge your Apple based Lightning device because you have the wrong cable... this adapter is the affordable perfect solution. Ideal for families that have multiple types of phones/tablets. 3 tips included per pack.
CAD 11.99  $19.99'Not yet rated.'Out of StockAdd Visiontek Micro USB to Lightning Tip Adapter 3 Pack for iPad mini 3 to Cart
Visiontek Lightning to USB .25 Meter Cable (Apple Approved) for iPad mini 350%Visiontek Lightning to USB .25 Meter Cable (Apple Approved) for iPad mini 3
CAD 9.99  $19.99'Not yet rated.'In StockAdd Visiontek Lightning to USB .25 Meter Cable (Apple Approved) for iPad mini 3 to Cart
Griffin Technology Lightning/USB Data Transfer Cable for iPad mini 3Griffin Technology Lightning/USB Data Transfer Cable for iPad mini 3
Our Lightning Connector cable is almost 10-Feet long and built with heavy-duty 20-gauge conductors to handle the 10 watt power needs of Apple's iPad. Connect this cable to your computer's USB port to sync your iPad, iPod, or iPhone; or to any 10 watt USB power source (we suggest our own PowerBlock or PowerJolt) and charge from 10-Feet away.
CAD 22.99  $26.99'Not yet rated.'Ships 1/24Add Griffin Technology Lightning/USB Data Transfer Cable for iPad mini 3 to Cart
StarTech.com 3-Feet 8-Pin Lightning to USB Charge Sync Cable for iPad mini 343%StarTech.com 3-Feet 8-Pin Lightning to USB Charge Sync Cable for iPad mini 3
Charge And Sync Your Apple Lightning-Equipped Devices - The 3-Feet 8-Pin Lightning to USB Cable.
CAD 19.99  $34.99'Not yet rated.'Ships 1/24Add StarTech.com 3-Feet 8-Pin Lightning to USB Charge Sync Cable for iPad mini 3 to Cart
StarTech.com 3-Feet 8-Pin Lightning to USB Charge Sync Cable for iPad mini 3StarTech.com 3-Feet 8-Pin Lightning to USB Charge Sync Cable for iPad mini 3
CAD 19.99  $29.99'Not yet rated.'Ships 1/24Add StarTech.com 3-Feet 8-Pin Lightning to USB Charge Sync Cable for iPad mini 3 to Cart
My iPad mini 3
Shop by Category
Customer Care
Powered by...
Our Customers Say...
