iPad mini Spare Parts
Browse Spare Parts for iPad mini
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPad miniweBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPad mini
CAD 34.99  $45.99'Not yet rated.'Ships 3/1Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPad mini to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPad miniweBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPad mini
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPad mini to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPad miniweBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPad mini
CAD 29.99  $35.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPad mini to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPad miniweBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPad mini
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 3/1Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPad mini to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPad miniweBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPad mini
CAD 34.99  $44.99'Not yet rated.'Ships 3/1Add weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPad mini to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPad miniweBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPad mini
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Ships 3/1Add weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPad mini to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for iPad miniweBoost NMO Antenna 800/1900 MHz Omni Directional for iPad mini
CAD 19.99  $26.99'Not yet rated.'Ships 3/1Add weBoost NMO Antenna 800/1900 MHz Omni Directional for iPad mini to Cart
weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPad miniweBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPad mini
Wilson Electronics 901101 NMO Cellular Antenna Trunk Mount with cable allows you to mount any NMO Cellular Antenna to a trunk lid or window.
CAD 13.99  $24.99'Not yet rated.'In StockAdd weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPad mini to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPad miniweBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPad mini
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPad mini to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPad miniweBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPad mini
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPad mini to Cart
weBoost Marine Antenna Mount (901119) for iPad miniweBoost Marine Antenna Mount (901119) for iPad mini
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for iPad mini to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPad miniweBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPad mini
CAD 9.99  $9.99'Not yet rated.'Ships 3/1Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPad mini to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPad miniweBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPad mini
CAD 11.99  $14.99'Not yet rated.'In StockAdd weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPad mini to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPad miniweBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPad mini
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPad mini to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPad miniweBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPad mini
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPad mini to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPad miniweBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPad mini
CAD 39.99  $49.99'Not yet rated.'Ships 3/1Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPad mini to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPad miniweBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPad mini
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 3/1Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPad mini to Cart
weBoost DC 12v Hardwire Power Kit for iPad miniweBoost DC 12v Hardwire Power Kit for iPad mini
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for iPad mini to Cart
weBoost DC/DC 6 volt Power Supply for iPad miniweBoost DC/DC 6 volt Power Supply for iPad mini
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for iPad mini to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPad miniweBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPad mini
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPad mini to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPad miniweBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPad mini
CAD 19.99  $26.99'Not yet rated.'Out of StockAdd weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPad mini to Cart
weBoost Home Accessory Kit for Sleek Amp for iPad miniweBoost Home Accessory Kit for Sleek Amp for iPad mini
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for iPad mini to Cart
weBoost Battery Pack for iPad miniweBoost Battery Pack for iPad mini
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for iPad mini to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPad miniweBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPad mini
CAD 35.99  $35.99'Not yet rated.'Out of StockAdd weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPad mini to Cart
weBoost Adjustable Suction Cup Mount for iPad miniweBoost Adjustable Suction Cup Mount for iPad mini
CAD 23.99  $27.99'Not yet rated.'Out of StockAdd weBoost Adjustable Suction Cup Mount for iPad mini to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPad miniweBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPad mini
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPad mini to Cart
weBoost 4G-X OTR Drive Kit for iPad miniweBoost 4G-X OTR Drive Kit for iPad mini
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Pre-OrderAdd weBoost 4G-X OTR Drive Kit for iPad mini to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPad miniweBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPad mini
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPad mini to Cart
My iPad mini
Shop by Category
Trending Purchases
Customer Care
Powered by...
Our Customers Say...
