iPad Spare Parts
Browse Spare Parts for iPad
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPadweBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPad
CAD 34.99  $45.99'Not yet rated.'Ships 1/25Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPad to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPadweBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPad
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPad to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPadweBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPad
CAD 29.99  $35.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPad to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPadweBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPad
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 1/25Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPad to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPadweBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPad
CAD 34.99  $44.99'Not yet rated.'Out of StockAdd weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPad to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPadweBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPad
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Ships 1/25Add weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPad to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for iPadweBoost NMO Antenna 800/1900 MHz Omni Directional for iPad
CAD 19.99  $26.99'Not yet rated.'Ships 1/25Add weBoost NMO Antenna 800/1900 MHz Omni Directional for iPad to Cart
weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPadweBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPad
Wilson Electronics 901101 NMO Cellular Antenna Trunk Mount with cable allows you to mount any NMO Cellular Antenna to a trunk lid or window.
CAD 13.99  $24.99'Not yet rated.'In StockAdd weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPad to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPadweBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPad
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPad to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPadweBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPad
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPad to Cart
weBoost Marine Antenna Mount (901119) for iPadweBoost Marine Antenna Mount (901119) for iPad
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for iPad to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPadweBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPad
CAD 9.99  $9.99'Not yet rated.'Ships 1/25Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPad to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPadweBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPad
CAD 11.99  $14.99'Not yet rated.'Ships 1/25Add weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPad to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPadweBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPad
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPad to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPadweBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPad
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPad to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPadweBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPad
CAD 39.99  $49.99'Not yet rated.'Ships 1/25Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPad to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPadweBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPad
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 1/25Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPad to Cart
weBoost DC 12v Hardwire Power Kit for iPadweBoost DC 12v Hardwire Power Kit for iPad
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for iPad to Cart
weBoost DC/DC 6 volt Power Supply for iPadweBoost DC/DC 6 volt Power Supply for iPad
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for iPad to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPadweBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPad
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPad to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPadweBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPad
CAD 19.99  $26.99'Not yet rated.'In StockAdd weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPad to Cart
weBoost Home Accessory Kit for Sleek Amp for iPadweBoost Home Accessory Kit for Sleek Amp for iPad
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for iPad to Cart
weBoost Battery Pack for iPadweBoost Battery Pack for iPad
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for iPad to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPadweBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPad
CAD 35.99  $35.99'Not yet rated.'Out of StockAdd weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPad to Cart
weBoost Adjustable Suction Cup Mount for iPadweBoost Adjustable Suction Cup Mount for iPad
CAD 23.99  $27.99'Not yet rated.'Ships 1/25Add weBoost Adjustable Suction Cup Mount for iPad to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPadweBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPad
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPad to Cart
weBoost 4G-X OTR Drive Kit for iPadweBoost 4G-X OTR Drive Kit for iPad
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Pre-OrderAdd weBoost 4G-X OTR Drive Kit for iPad to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPadweBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPad
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPad to Cart
My iPad
Shop by Category
Trending Purchases
Customer Care
Powered by...
Our Customers Say...
