iPhone 3G Spare Parts
Browse Spare Parts for iPhone 3G
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPhone 3GweBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPhone 3G
CAD 34.99  $45.99'Not yet rated.'Ships 1/21Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPhone 3G to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPhone 3GweBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPhone 3G
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPhone 3G to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPhone 3GweBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPhone 3G
CAD 29.99  $35.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPhone 3G to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPhone 3GweBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPhone 3G
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 1/21Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPhone 3G to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPhone 3GweBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPhone 3G
CAD 34.99  $44.99'Not yet rated.'Out of StockAdd weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPhone 3G to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPhone 3GweBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPhone 3G
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Ships 1/21Add weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPhone 3G to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for iPhone 3GweBoost NMO Antenna 800/1900 MHz Omni Directional for iPhone 3G
CAD 19.99  $26.99'Not yet rated.'Ships 1/21Add weBoost NMO Antenna 800/1900 MHz Omni Directional for iPhone 3G to Cart
weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPhone 3GweBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPhone 3G
Wilson Electronics 901101 NMO Cellular Antenna Trunk Mount with cable allows you to mount any NMO Cellular Antenna to a trunk lid or window.
CAD 13.99  $24.99'Not yet rated.'In StockAdd weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPhone 3G to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPhone 3GweBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPhone 3G
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPhone 3G to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPhone 3GweBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPhone 3G
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPhone 3G to Cart
weBoost Marine Antenna Mount (901119) for iPhone 3GweBoost Marine Antenna Mount (901119) for iPhone 3G
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for iPhone 3G to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPhone 3GweBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPhone 3G
CAD 9.99  $9.99'Not yet rated.'Ships 1/21Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPhone 3G to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPhone 3GweBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPhone 3G
CAD 11.99  $14.99'Not yet rated.'Ships 1/21Add weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPhone 3G to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPhone 3GweBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPhone 3G
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPhone 3G to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPhone 3GweBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPhone 3G
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPhone 3G to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPhone 3GweBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPhone 3G
CAD 39.99  $49.99'Not yet rated.'Ships 1/21Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPhone 3G to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPhone 3GweBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPhone 3G
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 1/21Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPhone 3G to Cart
weBoost DC 12v Hardwire Power Kit for iPhone 3GweBoost DC 12v Hardwire Power Kit for iPhone 3G
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for iPhone 3G to Cart
weBoost DC/DC 6 volt Power Supply for iPhone 3GweBoost DC/DC 6 volt Power Supply for iPhone 3G
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for iPhone 3G to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPhone 3GweBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPhone 3G
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPhone 3G to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPhone 3GweBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPhone 3G
CAD 19.99  $26.99'Not yet rated.'In StockAdd weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPhone 3G to Cart
weBoost Home Accessory Kit for Sleek Amp for iPhone 3GweBoost Home Accessory Kit for Sleek Amp for iPhone 3G
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for iPhone 3G to Cart
weBoost Battery Pack for iPhone 3GweBoost Battery Pack for iPhone 3G
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for iPhone 3G to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPhone 3GweBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPhone 3G
CAD 35.99  $35.99'Not yet rated.'Out of StockAdd weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPhone 3G to Cart
weBoost Adjustable Suction Cup Mount for iPhone 3GweBoost Adjustable Suction Cup Mount for iPhone 3G
CAD 23.99  $27.99'Not yet rated.'Ships 1/21Add weBoost Adjustable Suction Cup Mount for iPhone 3G to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPhone 3GweBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPhone 3G
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPhone 3G to Cart
weBoost 4G-X OTR Drive Kit for iPhone 3GweBoost 4G-X OTR Drive Kit for iPhone 3G
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Pre-OrderAdd weBoost 4G-X OTR Drive Kit for iPhone 3G to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPhone 3GweBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPhone 3G
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPhone 3G to Cart
My iPhone 3G
Shop by Category
Customer Care
Powered by...
Our Customers Say...
