iPhone 3GS Spare Parts
Browse Spare Parts for iPhone 3GS
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPhone 3GSweBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPhone 3GS
CAD 34.99  $45.99'Not yet rated.'Ships 1/19Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPhone 3GS to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPhone 3GSweBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPhone 3GS
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPhone 3GS to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPhone 3GSweBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPhone 3GS
CAD 29.99  $35.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPhone 3GS to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPhone 3GSweBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPhone 3GS
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 1/19Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPhone 3GS to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPhone 3GSweBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPhone 3GS
CAD 34.99  $44.99'Not yet rated.'Out of StockAdd weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPhone 3GS to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPhone 3GSweBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPhone 3GS
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Ships 1/19Add weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPhone 3GS to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for iPhone 3GSweBoost NMO Antenna 800/1900 MHz Omni Directional for iPhone 3GS
CAD 19.99  $26.99'Not yet rated.'Ships 1/19Add weBoost NMO Antenna 800/1900 MHz Omni Directional for iPhone 3GS to Cart
weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPhone 3GSweBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPhone 3GS
Wilson Electronics 901101 NMO Cellular Antenna Trunk Mount with cable allows you to mount any NMO Cellular Antenna to a trunk lid or window.
CAD 13.99  $24.99'Not yet rated.'In StockAdd weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPhone 3GS to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPhone 3GSweBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPhone 3GS
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPhone 3GS to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPhone 3GSweBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPhone 3GS
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPhone 3GS to Cart
weBoost Marine Antenna Mount (901119) for iPhone 3GSweBoost Marine Antenna Mount (901119) for iPhone 3GS
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for iPhone 3GS to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPhone 3GSweBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPhone 3GS
CAD 9.99  $9.99'Not yet rated.'Ships 1/19Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPhone 3GS to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPhone 3GSweBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPhone 3GS
CAD 11.99  $14.99'Not yet rated.'Ships 1/19Add weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPhone 3GS to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPhone 3GSweBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPhone 3GS
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPhone 3GS to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPhone 3GSweBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPhone 3GS
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPhone 3GS to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPhone 3GSweBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPhone 3GS
CAD 39.99  $49.99'Not yet rated.'Ships 1/19Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPhone 3GS to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPhone 3GSweBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPhone 3GS
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 1/19Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPhone 3GS to Cart
weBoost DC 12v Hardwire Power Kit for iPhone 3GSweBoost DC 12v Hardwire Power Kit for iPhone 3GS
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for iPhone 3GS to Cart
weBoost DC/DC 6 volt Power Supply for iPhone 3GSweBoost DC/DC 6 volt Power Supply for iPhone 3GS
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for iPhone 3GS to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPhone 3GSweBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPhone 3GS
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPhone 3GS to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPhone 3GSweBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPhone 3GS
CAD 19.99  $26.99'Not yet rated.'In StockAdd weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPhone 3GS to Cart
weBoost Home Accessory Kit for Sleek Amp for iPhone 3GSweBoost Home Accessory Kit for Sleek Amp for iPhone 3GS
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for iPhone 3GS to Cart
weBoost Battery Pack for iPhone 3GSweBoost Battery Pack for iPhone 3GS
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for iPhone 3GS to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPhone 3GSweBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPhone 3GS
CAD 35.99  $35.99'Not yet rated.'Out of StockAdd weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPhone 3GS to Cart
weBoost Adjustable Suction Cup Mount for iPhone 3GSweBoost Adjustable Suction Cup Mount for iPhone 3GS
CAD 23.99  $27.99'Not yet rated.'Ships 1/19Add weBoost Adjustable Suction Cup Mount for iPhone 3GS to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPhone 3GSweBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPhone 3GS
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPhone 3GS to Cart
weBoost 4G-X OTR Drive Kit for iPhone 3GSweBoost 4G-X OTR Drive Kit for iPhone 3GS
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Pre-OrderAdd weBoost 4G-X OTR Drive Kit for iPhone 3GS to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPhone 3GSweBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPhone 3GS
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPhone 3GS to Cart
My iPhone 3GS
Shop by Category
Customer Care
Powered by...
Our Customers Say...
