iPhone 5 Spare Parts
Browse Spare Parts for iPhone 5
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPhone 5weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPhone 5
CAD 34.99  $45.99'Not yet rated.'Ships 5/8Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPhone 5 to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPhone 5weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPhone 5
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPhone 5 to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPhone 5weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPhone 5
CAD 29.99  $35.99'Not yet rated.'Ships 5/8Add weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPhone 5 to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPhone 5weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPhone 5
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 5/8Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPhone 5 to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPhone 5weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPhone 5
CAD 34.99  $44.99'Not yet rated.'Out of StockAdd weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPhone 5 to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPhone 5weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPhone 5
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Out of StockAdd weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPhone 5 to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for iPhone 5weBoost NMO Antenna 800/1900 MHz Omni Directional for iPhone 5
CAD 19.99  $26.99'Not yet rated.'Ships 5/8Add weBoost NMO Antenna 800/1900 MHz Omni Directional for iPhone 5 to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPhone 5weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPhone 5
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPhone 5 to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPhone 5weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPhone 5
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPhone 5 to Cart
weBoost Marine Antenna Mount (901119) for iPhone 5weBoost Marine Antenna Mount (901119) for iPhone 5
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for iPhone 5 to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPhone 5weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPhone 5
CAD 9.99  $9.99'Not yet rated.'Ships 5/8Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPhone 5 to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPhone 5weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPhone 5
CAD 11.99  $14.99'Not yet rated.'In StockAdd weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPhone 5 to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPhone 5weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPhone 5
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPhone 5 to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPhone 5weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPhone 5
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPhone 5 to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPhone 5weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPhone 5
CAD 39.99  $49.99'Not yet rated.'Ships 5/8Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPhone 5 to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPhone 5weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPhone 5
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 5/8Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPhone 5 to Cart
weBoost DC 12v Hardwire Power Kit for iPhone 5weBoost DC 12v Hardwire Power Kit for iPhone 5
CAD 9.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for iPhone 5 to Cart
weBoost DC/DC 6 volt Power Supply for iPhone 5weBoost DC/DC 6 volt Power Supply for iPhone 5
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for iPhone 5 to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPhone 5weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPhone 5
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPhone 5 to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPhone 5weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPhone 5
CAD 19.99  $26.99'Not yet rated.'In StockView weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPhone 5 Options
weBoost Battery Pack for iPhone 5weBoost Battery Pack for iPhone 5
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for iPhone 5 to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPhone 5weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPhone 5
CAD 35.99  $35.99'Not yet rated.'Ships 5/8Add weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPhone 5 to Cart
weBoost Adjustable Suction Cup Mount for iPhone 5weBoost Adjustable Suction Cup Mount for iPhone 5
CAD 23.99  $27.99'Not yet rated.'Ships 5/8Add weBoost Adjustable Suction Cup Mount for iPhone 5 to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPhone 5weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPhone 5
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPhone 5 to Cart
weBoost 3G-S Drive Kit - 2 Year In-Store Warranty for iPhone 5weBoost 3G-S Drive Kit - 2 Year In-Store Warranty for iPhone 5
Stay connected as you drive with the WeBoost 3G-S Drive signal booster kit. Designed for easy install, the 3G-S Drive keeps your phone connected to cellsites when trees, hills and buildings get in the way. Reduce dropped calls, widen your coverage area and improve data speeds on Canada's major networks with the Drive 3G-S. Boosts voice and 3G services. This product is covered by a 2 year warranty which we assume on behalf of the manufacturer.
Free Shipping
CAD 144.99  $149.99'Not yet rated.'Ships 5/8Add weBoost 3G-S Drive Kit - 2 Year In-Store Warranty for iPhone 5 to Cart
weBoost 4G-S Drive Kit for iPhone 5weBoost 4G-S Drive Kit for iPhone 5
Stay connected as you drive with the WeBoost 4G-S Drive signal booster kit. Designed for easy install, the 4G-S Drive keeps your phone connected to cellsites when trees, hills and buildings get in the way. Reduce dropped calls, widen your coverage area and improve data speeds on all Canadian networks with the Drive 4G-S. Boosts voice, 3G, and 4G services.
Free Shipping
CAD 264.99  $269.99'Not yet rated.'Pre-OrderAdd weBoost 4G-S Drive Kit for iPhone 5 to Cart
weBoost 4G-M Drive Kit for iPhone 5weBoost 4G-M Drive Kit for iPhone 5
Multiple users can stay connected as you drive, with the WeBoost 4G-M Drive signal booster kit. Designed for easy install, the 4G-M Drive keeps your phone, and others, connected to cell sites when trees, hills and buildings get in the way. Reduce dropped calls, widen your coverage area and speed up data speeds on Canada's major networks with the Drive 4G-M. Boosts voice, 3G, and 4G services.
Free Shipping
CAD 574.99  $579.99'Not yet rated.'Pre-OrderAdd weBoost 4G-M Drive Kit for iPhone 5 to Cart
weBoost 3G-X Drive Kit for iPhone 5weBoost 3G-X Drive Kit for iPhone 5
Our most powerful 3G in-vehicle signal booster, the WeBoost 3G-X Drive keeps multiple users connected on the road. Designed for easy install, the 3G-X Drive keeps your phone, and others, connected to cellsites in remote, low-signal locations. Reduce dropped calls, maximize your coverage area and improve data speeds on Canada's major networks with the Drive 3G-X. Boosts voice and 3G services.
Free Shipping
CAD 599.99  $604.99'Not yet rated.'Ships 5/8Add weBoost 3G-X Drive Kit for iPhone 5 to Cart
weBoost 3G-Flex Drive Kit for iPhone 5weBoost 3G-Flex Drive Kit for iPhone 5
Need a signal booster that can travel with you? The 3G-Flex Drive signal booster kit can be used in the car, brought inside, or even carried around because it`s powered by USB, DC or AC adapters (all included). Boosts voice and 3G services for multiple phones/devices in a 3 foot radius.
Free Shipping
CAD 294.99  $299.99'Not yet rated.'Ships 5/8Add weBoost 3G-Flex Drive Kit for iPhone 5 to Cart
weBoost 4G Home Kit for iPhone 5weBoost 4G Home Kit for iPhone 5
Stop wandering about your home looking for a better cellphone connection. The WeBoost Home 4G signal booster kit delivers stronger signal for 1-2 rooms in your home, providing better voice quality and faster internet connection speeds on all Canadian networks. Boosts voice, 3G and 4G services on all cellular connected devices, like phones, tablets, routers and more.
Free Shipping
CAD 654.99  $659.99'Not yet rated.'Ships 5/8Add weBoost 4G Home Kit for iPhone 5 to Cart
weBoost 3G Home Kit for iPhone 5weBoost 3G Home Kit for iPhone 5
Stop wandering about your home looking for a better cellphone connection. The WeBoost Home 3G signal booster kit delivers stronger signal for 1-2 rooms in your home, providing better voice quality and faster internet connection speeds on the major Canadian networks. Boosts voice and 3G services on all cellular connected devices, like phones, tablets, routers and more.
Free Shipping
CAD 434.99  $439.99'Not yet rated.'Pre-OrderAdd weBoost 3G Home Kit for iPhone 5 to Cart
weBoost 4G Connect Kit for iPhone 5weBoost 4G Connect Kit for iPhone 5
Bring your building a better cellphone connection. The WeBoost Connect 4G signal booster kit delivers stronger signal for small homes, cabins, or businesses, providing better voice quality and faster internet connection speeds on all Canadian networks. Boosts voice, 3G and 4G services on all cellular connected devices, like phones, tablets, routers and more.
Free Shipping
CAD 829.99  $834.99'Not yet rated.'Ships 5/8Add weBoost 4G Connect Kit for iPhone 5 to Cart
weBoost 3G-Directional Connect Kit for iPhone 5weBoost 3G-Directional Connect Kit for iPhone 5
Bring your building a better cellphone connection. The WeBoost Connect 3G signal booster kit delivers stronger signal for small homes, cabins, or businesses, providing better voice quality and faster internet connection speeds on the major Canadian networks. Boosts voice and 3G services on all cellular connected devices, like phones, tablets, routers and more.
Free Shipping
CAD 654.99  $659.99'Not yet rated.'Pre-OrderAdd weBoost 3G-Directional Connect Kit for iPhone 5 to Cart
weBoost 4G-X Connect Kit for iPhone 5weBoost 4G-X Connect Kit for iPhone 5
Fill your home or business with better cellphone signal. The WeBoost Connect 4G-X signal booster kit delivers stronger signal for large homes and businesses, providing better voice quality and faster internet connection speeds on all Canadian networks. Boosts voice, 3G and 4G services on all cellular connected devices, like phones, tablets, routers and more.
CAD 1,424.99  $1,429.99'Not yet rated.'Ships 5/8Add weBoost 4G-X Connect Kit for iPhone 5 to Cart
weBoost 4G-X OTR Drive Kit for iPhone 5weBoost 4G-X OTR Drive Kit for iPhone 5
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Ships 5/8Add weBoost 4G-X OTR Drive Kit for iPhone 5 to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPhone 5weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPhone 5
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPhone 5 to Cart
My iPhone 5
Shop by Category
Customer Care
Powered by...
Our Customers Say...
