iPhone 5S Spare Parts
Browse Spare Parts for iPhone 5S
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPhone 5SweBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPhone 5S
CAD 34.99  $45.99'Not yet rated.'Ships 3/29Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPhone 5S to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPhone 5SweBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPhone 5S
CAD 29.99  $32.99'Not yet rated.'Ships 3/29Add weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPhone 5S to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPhone 5SweBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPhone 5S
CAD 29.99  $35.99'Not yet rated.'Ships 3/29Add weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPhone 5S to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPhone 5SweBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPhone 5S
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 3/29Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPhone 5S to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPhone 5SweBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPhone 5S
CAD 34.99  $44.99'Not yet rated.'Ships 3/29Add weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPhone 5S to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPhone 5SweBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPhone 5S
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Ships 3/29Add weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPhone 5S to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for iPhone 5SweBoost NMO Antenna 800/1900 MHz Omni Directional for iPhone 5S
CAD 19.99  $26.99'Not yet rated.'Ships 3/29Add weBoost NMO Antenna 800/1900 MHz Omni Directional for iPhone 5S to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPhone 5SweBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPhone 5S
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPhone 5S to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPhone 5SweBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPhone 5S
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPhone 5S to Cart
weBoost Marine Antenna Mount (901119) for iPhone 5SweBoost Marine Antenna Mount (901119) for iPhone 5S
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for iPhone 5S to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPhone 5SweBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPhone 5S
CAD 9.99  $9.99'Not yet rated.'Ships 3/29Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPhone 5S to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPhone 5SweBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPhone 5S
CAD 11.99  $14.99'Not yet rated.'In StockAdd weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPhone 5S to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPhone 5SweBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPhone 5S
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPhone 5S to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPhone 5SweBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPhone 5S
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPhone 5S to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPhone 5SweBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPhone 5S
CAD 39.99  $49.99'Not yet rated.'Ships 3/29Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPhone 5S to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPhone 5SweBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPhone 5S
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 3/29Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPhone 5S to Cart
weBoost DC 12v Hardwire Power Kit for iPhone 5SweBoost DC 12v Hardwire Power Kit for iPhone 5S
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for iPhone 5S to Cart
weBoost DC/DC 6 volt Power Supply for iPhone 5SweBoost DC/DC 6 volt Power Supply for iPhone 5S
CAD 37.99  $48.99'Not yet rated.'Ships 3/29Add weBoost DC/DC 6 volt Power Supply for iPhone 5S to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPhone 5SweBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPhone 5S
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPhone 5S to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPhone 5SweBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPhone 5S
CAD 19.99  $26.99'Not yet rated.'Ships 3/29Add weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPhone 5S to Cart
weBoost Home Accessory Kit for Sleek Amp for iPhone 5SweBoost Home Accessory Kit for Sleek Amp for iPhone 5S
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for iPhone 5S to Cart
weBoost Battery Pack for iPhone 5SweBoost Battery Pack for iPhone 5S
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for iPhone 5S to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPhone 5SweBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPhone 5S
CAD 35.99  $35.99'Not yet rated.'Ships 3/29Add weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPhone 5S to Cart
weBoost Adjustable Suction Cup Mount for iPhone 5SweBoost Adjustable Suction Cup Mount for iPhone 5S
CAD 23.99  $27.99'Not yet rated.'Ships 3/29Add weBoost Adjustable Suction Cup Mount for iPhone 5S to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPhone 5SweBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPhone 5S
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPhone 5S to Cart
weBoost 4G-X OTR Drive Kit for iPhone 5SweBoost 4G-X OTR Drive Kit for iPhone 5S
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Ships 3/29Add weBoost 4G-X OTR Drive Kit for iPhone 5S to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPhone 5SweBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPhone 5S
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPhone 5S to Cart
My iPhone 5S
Shop by Category
Trending Purchases
Customer Care
Powered by...
Our Customers Say...
