iPhone Speaker Systems
Browse Speaker Systems for iPhone
Sort by:
Narrow By:
XMI Max Duo Speaker (Gunmetal) for iPhone71%XMI Max Duo Speaker (Gunmetal) for iPhone
The MAX offers a new standard in portable speakers with the introduction of the ceramic tweeter. The quality of sound produced from any speaker depends largely on the tweeter material and after months of research, trials and prototype development, the engineering team at Xmi Pte Ltd found that ceramic was the most suitable material to bring the X-miniā„¢ sound to the next level. The ceramic tweeter brings about several advantages. As compared to aluminum tweeters, the ceramic ones can produce a wider frequency range covering higher and lower sounds. As a result of that, the distortion of sound is also much reduced because the ceramic tweeter is able to withstand high and low frequencies without producing any cracks in the sound.
CAD 19.99  $69.99'Not yet rated.'In StockAdd XMI Max Duo Speaker (Gunmetal) for iPhone to Cart
XMI Uno Ceramic Speaker (Orange) for iPhone71%XMI Uno Ceramic Speaker (Orange) for iPhone
The ceramic tweeter brings about several advantages. As compared to aluminum tweeters, the ceramic ones can produce a wider frequency range covering higher and lower sounds. As a result, the distortion of sound is also much reduced because the ceramic tweeter is able to withstand high and low frequencies without producing any cracks in the sound.When a speaker plays low frequency sound, it is difficult to maintain the depth and intensity of the bass produced. A tweeter that does not have a high enough efficiency will not be able to support a strong bass, resulting in soft and clouded music that lacks intensity.
CAD 9.99  $34.99'Not yet rated.'In StockAdd XMI Uno Ceramic Speaker (Orange) for iPhone to Cart
XMI Uno Ceramic Speaker (Purple) for iPhone71%XMI Uno Ceramic Speaker (Purple) for iPhone
CAD 9.99  $34.99'Not yet rated.'In StockAdd XMI Uno Ceramic Speaker (Purple) for iPhone to Cart
Xtreme Bluetooth Shower Speaker for iPhoneXtreme Bluetooth Shower Speaker for iPhone
Truly experience your music wherever you are with the Xtreme Splash Series Bluetooth Shower Speaker. You can listen to all of your favorite songs near any wet area. With its water resistance design you can be sure that water will stay out. Its bluetooth capability allows you to answer calls right from the speaker, making sure you never miss any important calls. The suction cup feature allows it to stick to virtually any surface. Enjoy your music in the Xtreme way.
CAD 16.99  $16.99'Not yet rated.'Ships 2/28Add Xtreme Bluetooth Shower Speaker for iPhone to Cart
CAD 16.99  $16.99'Not yet rated.'In StockAdd Xtreme Bluetooth Shower Speaker for iPhone to Cart
Xtreme Mini Round Bluetooth Speaker for iPhoneXtreme Mini Round Bluetooth Speaker for iPhone
Mini compact design with great audio quality.
CAD 16.99  $16.99'Not yet rated.'Out of StockAdd Xtreme Mini Round Bluetooth Speaker for iPhone to Cart
Xtreme Durapod Rugged Weatherproof Bluetooth Speaker for iPhoneXtreme Durapod Rugged Weatherproof Bluetooth Speaker for iPhone
Durapod Rugged Weatherproof Bluetooth Speaker with Full Audio Control and Auxiliary Input for Non-Bluetooth Devices.
CAD 29.99  $29.99'Not yet rated.'Ships 2/28Add Xtreme Durapod Rugged Weatherproof Bluetooth Speaker for iPhone to Cart
My iPhone
Shop by Category
Trending Purchases
Customer Care
Powered by...
Our Customers Say...
