iPod classic 160GB Car Kits & Mounts
Browse Car Kits & Mounts for iPod classic 160GB
Sort by:
Narrow By:
iOttie Universal Car Mount (HLCRIO102) for iPod classic 160GB43%iOttie Universal Car Mount (HLCRIO102) for iPod classic 160GB
The iOttie One-Touch Windshield Dashboard Car Mount's main focus is functionality. Its simple one-touch system allows for the mounting and releasing of the device with only the push of one finger. Thanks to its super strong extra-large suction cup, the One-Touch Car Mount sticks securely to most smooth flat surfaces, yet is still easily removable.
CAD 19.99  $34.95Score 2.3/5Score 2.3/5Score 2.3/5Score 2.3/5Score 2.3/5 (3)In StockAdd iOttie Universal Car Mount (HLCRIO102) for iPod classic 160GB to Cart
iOttie Easy One Touch XL Universal Car Mount for iPod classic 160GBiOttie Easy One Touch XL Universal Car Mount for iPod classic 160GB
The iOttie Easy One Touch XL is a durable, universal car mount that lets your phone safely and easily rest on your dashboard, windshield or desk.
CAD 24.95  $29.99'Not yet rated.'In StockAdd iOttie Easy One Touch XL Universal Car Mount for iPod classic 160GB to Cart
Nite Ize Steelie Car Mount Kit for iPod classic 160GBNite Ize Steelie Car Mount Kit for iPod classic 160GB
The Nite Ize Steelie Car Mount Kit is the perfect phone holder for your car. It docks your iPod classic 160GB to your dashboard in a snap, so it's visible, accessible, and right where you need it, everywhere you go. Here's how it works: two specially engineered components - the Steelie Magnetic Phone Socket and Steelie Ball Mount - are backed with 3M VHB foam adhesive tape, to provide secure-yet-versatile phone docking exactly where you need it.
CAD 37.99  $49.99Score 3/5Score 3/5Score 3/5Score 3/5Score 3/5 (2)Out of StockAdd Nite Ize Steelie Car Mount Kit for iPod classic 160GB to Cart
MYBAT Car Mount for Smartphones with or without Case for iPod classic 160GBMYBAT Car Mount for Smartphones with or without Case for iPod classic 160GB
Universal Car Mount which accommodates all types of Smartphones, with our without Case. Has 2 mounting options: Vent Mount (included) and Windshield Mount/Dashboard Mount (via included Suction Cup)
CAD 12.99  $29.99Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5Score 3.7/5 (3)In StockAdd MYBAT Car Mount for Smartphones with or without Case for iPod classic 160GB to Cart
Nite Ize Steelie Magnetic Phone Socket Replacement Kit for iPod classic 160GBNite Ize Steelie Magnetic Phone Socket Replacement Kit for iPod classic 160GB
Perfect for families that have multiple mobile phones or devices, but who share a vehicle or workspace utilizing a Steelie Car Mount Kit.
CAD 14.99  $19.99'Not yet rated.'In StockAdd Nite Ize Steelie Magnetic Phone Socket Replacement Kit for iPod classic 160GB to Cart
iOttie Easy One Touch 2 Universal Car Mount for iPod classic 160GBiOttie Easy One Touch 2 Universal Car Mount for iPod classic 160GB
The iOttie Easy One Touch 2 provides a safe, versatile and highly functional smartphone mounting solution!
CAD 31.95'Not yet rated.'In StockAdd iOttie Easy One Touch 2 Universal Car Mount for iPod classic 160GB to Cart
Macally Adjustable Automobile Cup Holder Mount for iPod classic 160GBMacally Adjustable Automobile Cup Holder Mount for iPod classic 160GB
The Adjustable Automobile Cup Holder Mount from Macally is a mount for your cell phone, smartphone, GPS or PDA that fits into the cup holder in your car. The base is adjustable, allowing it to fit snugly into a variety of cup holder sizes. Meanwhile, the flexible neck allows you to customize the viewing angle of your device and the swivel holder lets you situate it either vertically or horizontally. The mount has soft grips and non-scratch backing for maximum protection.
CAD 19.99  $29.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockAdd Macally Adjustable Automobile Cup Holder Mount for iPod classic 160GB to Cart
iQ Magnetic Universal Windshield Car Mount for iPod classic 160GB48%iQ Magnetic Universal Windshield Car Mount for iPod classic 160GB
Magnetic mounting system for supporting your smartphone. Just hover your device near the mount and it instantly locks in place!
CAD 12.99  $24.99'Not yet rated.'In StockAdd iQ Magnetic Universal Windshield Car Mount for iPod classic 160GB to Cart
iQ Magnetic Universal Vent Car Mount for iPod classic 160GB48%iQ Magnetic Universal Vent Car Mount for iPod classic 160GB
CAD 12.99  $24.99'Not yet rated.'In StockAdd iQ Magnetic Universal Vent Car Mount for iPod classic 160GB to Cart
Nite Ize Steelie Vent Mount Kit for iPod classic 160GBNite Ize Steelie Vent Mount Kit for iPod classic 160GB
The Nite Ize Steelie Vent Mount Kit is a brilliant solution for keeping your smartphone secure and visible when you're in the car. It consists of two simple components: 1) a Steelie Magnetic Phone Socket that adheres semi-permanently with 3M® VHB™ foam tape, either to the back of your case or to the phone itself, and 2) a versatile Steelie Vent Ball Mount that securely clips to most vehicle vents, and is just as easy to unclip, so it can be used in multiple vehicles. The Vent Ball's round shape allows radiant positioning options, so you can tilt your phone to any angle, and the strong magnetic attachment of the Steelie Phone Magnet Socket keeps your phone securely in place and where you need it.
CAD 49.99  $59.99'Not yet rated.'In StockAdd Nite Ize Steelie Vent Mount Kit for iPod classic 160GB to Cart
Kenu Airframe+ Portable Car Mount (Leather Edition) for iPod classic 160GBKenu Airframe+ Portable Car Mount (Leather Edition) for iPod classic 160GB
Crafted with genuine leather and gold chrome accents, the Kenu Airframe+ Leather Edition is a stylish addition to any console. It`s simple to use, just attach Airframe on to any air vent in your vehicle it will support all smartphones and phablets with up to 6-inch screens.
CAD 49.99  $49.99'Not yet rated.'In StockAdd Kenu Airframe+ Portable Car Mount (Leather Edition) for iPod classic 160GB to Cart
iOttie Easy One Touch MiniVent Mount for iPod classic 160GBiOttie Easy One Touch MiniVent Mount for iPod classic 160GB
The iOttie Easy One Touch Mini is a compact and fully functional yet sophisticated mounting solution that fits easily into any vent in most vehicles. This mount provides a safe, versatile, and highly functional smartphone mounting solution.
CAD 28.95  $34.95'Not yet rated.'In StockAdd iOttie Easy One Touch MiniVent Mount for iPod classic 160GB to Cart
Mobi Products Universal Magnetic Car Windshield Mount for iPod classic 160GB71%Mobi Products Universal Magnetic Car Windshield Mount for iPod classic 160GB
This gadget allows the phone owner to easily stick their phone on to the windshield mount using a magnet. Simply stick a slim metal adhesive sheet to the back of the phone or case, and start using the device.
CAD 9.99  $34.99'Not yet rated.'In StockAdd Mobi Products Universal Magnetic Car Windshield Mount for iPod classic 160GB to Cart
Mobi Products Universal Magnetic Air Vent Mount for iPod classic 160GB67%Mobi Products Universal Magnetic Air Vent Mount for iPod classic 160GB
This gadget allows the phone owner to easily stick their phone to the air vent mount using a magnet. Simply stick a slim metal adhesive sheet to the back of the phone or case, and start using the device.
CAD 9.99  $29.99'Not yet rated.'In StockAdd Mobi Products Universal Magnetic Air Vent Mount for iPod classic 160GB to Cart
Macally Adjustable Cup Holder for All Portable Devices in Vehicle
CAD 19.99  $29.99Score 3/5Score 3/5Score 3/5Score 3/5Score 3/5 (1)In StockAdd Macally Adjustable Automobile Cup Holder Mount for iPod classic 160GB to Cart
Macally Suction Cup Mount for iPod classic 160GBMacally Suction Cup Mount for iPod classic 160GB
Holds your device in Vertical or Horizontal position,Longer holder than mGRIP2 model, the MGRIP2MP fits taller phones. Phone Minimum width: 1.5 inches (3.6 cm) Maximum width: 3 5/8 inches (9.7 cm) Maximum height: 6 13/16 inches (17.3 cm)
CAD 28.99  $34.99Score 4/5Score 4/5Score 4/5Score 4/5Score 4/5 (1)In StockAdd Macally Suction Cup Mount for iPod classic 160GB to Cart
Smartphone Experts Universal Car Windshield Mount for iPod classic 160GB60%Smartphone Experts Universal Car Windshield Mount for iPod classic 160GB
Fast and easy to fit in any car, this Universal Car Phone Holder is fully adjustable for a comfortable viewing angle. It is easily adjusted to fit a wide range of handsets.
CAD 9.99  $24.99'Not yet rated.'In StockAdd Smartphone Experts Universal Car Windshield Mount for iPod classic 160GB to Cart
puregear Magnetic Universal Car Vent Mount for iPod classic 160GBpuregear Magnetic Universal Car Vent Mount for iPod classic 160GB
Magnetic Universal Car Vent Mount is compatible with all phones and mount easily to the car vent.
CAD 29.99  $34.99'Not yet rated.'In StockAdd puregear Magnetic Universal Car Vent Mount for iPod classic 160GB to Cart
puregear Magnetic Universal Car Dash Mount for iPod classic 160GBpuregear Magnetic Universal Car Dash Mount for iPod classic 160GB
Magnetic Universal Car Dash Mount is compatible with all phones and mount easily to the dashboard.
CAD 24.99  $39.99'Not yet rated.'Out of StockAdd puregear Magnetic Universal Car Dash Mount for iPod classic 160GB to Cart
Kenu Airframe+ Car Kit Deluxe for iPod classic 160GBKenu Airframe+ Car Kit Deluxe for iPod classic 160GB
The Airframe+ Car Kit Deluxe joins three of Kenu�s best accessories into the most streamlined travel experience. The Airframe+ provides a safe experience for drivers looking to mount their device in sight. Perfect for viewing your GPS, streaming music and taking hands-free calls and works with all smartphones and phablets with up to six-inch screens. The included Dualtrip in-car charger featuring two side-by-side USB ports that can charge multiple devices simultaneously at maximum speed. The included Tripline cable combines both Lightning and micro-USB connectors, allowing you to quickly charge your favourite devices.
Free Shipping
CAD 55.99  $69.99'Not yet rated.'Out of StockAdd Kenu Airframe+ Car Kit Deluxe for iPod classic 160GB to Cart
SCOSCHE Window/Dash Magic Mount for iPod classic 160GBSCOSCHE Window/Dash Magic Mount for iPod classic 160GB
Magic mount is a new magnetic mounting system for conveniently mounting your smartphone, GPS and more. Just hover your device near the magnetic surface and it instantly locks securely in place.
CAD 19.99  $29.99'Not yet rated.'In StockAdd SCOSCHE Window/Dash Magic Mount for iPod classic 160GB to Cart
SCOSCHE Vent Magic Mount for iPod classic 160GBSCOSCHE Vent Magic Mount for iPod classic 160GB
CAD 19.99  $29.99'Not yet rated.'Ships 5/2Add SCOSCHE Vent Magic Mount for iPod classic 160GB to Cart
Nite Ize HandleBand Universal Smartphone Bar Mount for iPod classic 160GBNite Ize HandleBand Universal Smartphone Bar Mount for iPod classic 160GB
The Handle Band is a universal smartphone bar mount that provides a secure attachment and instant access to almost any device on almost any sized handle bar.
CAD 19.95  $29.99'Not yet rated.'In StockAdd Nite Ize HandleBand Universal Smartphone Bar Mount for iPod classic 160GB to Cart
iOttie Active Edge Bike & Bar Mount for iPod classic 160GBiOttie Active Edge Bike & Bar Mount for iPod classic 160GB
Universal bike & bar mounting solution for bicycle, Motorcycle, Stroller and any bar diameter 0.85 in- 1.4 in (21.59mm- 35.56mm)
CAD 39.95  $44.95'Not yet rated.'In StockView iOttie Active Edge Bike & Bar Mount for iPod classic 160GB Options
weBoost 3G-S Drive Kit - 2 Year In-Store Warranty for iPod classic 160GBweBoost 3G-S Drive Kit - 2 Year In-Store Warranty for iPod classic 160GB
Stay connected as you drive with the WeBoost 3G-S Drive signal booster kit. Designed for easy install, the 3G-S Drive keeps your phone connected to cellsites when trees, hills and buildings get in the way. Reduce dropped calls, widen your coverage area and improve data speeds on Canada's major networks with the Drive 3G-S. Boosts voice and 3G services. This product is covered by a 2 year warranty which we assume on behalf of the manufacturer.
Free Shipping
CAD 144.99  $149.99'Not yet rated.'Ships 5/8Add weBoost 3G-S Drive Kit - 2 Year In-Store Warranty for iPod classic 160GB to Cart
weBoost 4G-S Drive Kit for iPod classic 160GBweBoost 4G-S Drive Kit for iPod classic 160GB
Stay connected as you drive with the WeBoost 4G-S Drive signal booster kit. Designed for easy install, the 4G-S Drive keeps your phone connected to cellsites when trees, hills and buildings get in the way. Reduce dropped calls, widen your coverage area and improve data speeds on all Canadian networks with the Drive 4G-S. Boosts voice, 3G, and 4G services.
Free Shipping
CAD 264.99  $269.99'Not yet rated.'Pre-OrderAdd weBoost 4G-S Drive Kit for iPod classic 160GB to Cart
Mobi Products Anti-Slip Mat for Car Dashboard for iPod classic 160GB50%Mobi Products Anti-Slip Mat for Car Dashboard for iPod classic 160GB
You can lay it on car dashboard for car holder, provide a good view and conveniently when driving. Also,a good choice as table stand for watching TV.
CAD 4.99  $9.99'Not yet rated.'In StockAdd Mobi Products Anti-Slip Mat for Car Dashboard for iPod classic 160GB to Cart
Clingo Universal Hands-Free Car Vent Mount for iPod classic 160GBClingo Universal Hands-Free Car Vent Mount for iPod classic 160GB
Hands-free. Safe driving. The Clingo Universal Vent Mount keeps your phone in view. Clingo's Universal Vent Mount allows you to keep your phone where you can glance at it if you need to, without taking your attention from the road. The highly adjustable ball and socket joint provides the flexibility to get the viewing angle just right. (Great for your new GPS App) And as always, the Clingo sticky pad holds your phone tightly, yet lets it go when you're ready to have it back. Let your phone stick to Clingo, so you can stick to driving. Clingo's Vent Mount is easy to install, and a great way to mount your cell phone with or without a hard shell protective case, including all models of the Apple's iPhone or iPod, Blackberry, Droid, or other Smartphones. Any phone, anywhere. It's pretty simple, really. Clingo holds any phone. It doesn't matter if it's a BlackBerry, iPhone, Samsung, latest Droid or whatever - Clingo holds it.
CAD 29.99  $39.99'Not yet rated.'In StockAdd Clingo Universal Hands-Free Car Vent Mount for iPod classic 160GB to Cart
iOttie Easy view 2 Universal Car Mount for iPod classic 160GBiOttie Easy view 2 Universal Car Mount for iPod classic 160GB
The iOttie Easy View 2 Car Mount is a sleek and compact designed mount. It incorporates our new GripFit locking feature. The Easy View 2 uses a 7mm ball joint as used on its predecessor to give you that 360 view that you have come to know and love and to expect from iOttie. The Easy View 2 also uses our super sticky gel pad as well as a strong locking lever to ensure your mount wont budge from its desired location. Easy View 2 is available in several different color options as well to suite your mood. Mount Smart. Drive Smarter!
CAD 19.99  $22.99'Not yet rated.'In StockAdd iOttie Easy view 2 Universal Car Mount for iPod classic 160GB to Cart
More Car Kits & Mounts...
My iPod classic 160GB
Shop by Category
Customer Care
Powered by...
Our Customers Say...
