iPod classic 160GB Spare Parts
Browse Spare Parts for iPod classic 160GB
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPod classic 160GBweBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPod classic 160GB
CAD 34.99  $45.99'Not yet rated.'Ships 1/19Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for iPod classic 160GB to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPod classic 160GBweBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPod classic 160GB
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for iPod classic 160GB to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPod classic 160GBweBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPod classic 160GB
CAD 29.99  $35.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for iPod classic 160GB to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPod classic 160GBweBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPod classic 160GB
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 1/19Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for iPod classic 160GB to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPod classic 160GBweBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPod classic 160GB
CAD 34.99  $44.99'Not yet rated.'Out of StockAdd weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for iPod classic 160GB to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPod classic 160GBweBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPod classic 160GB
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Ships 1/19Add weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for iPod classic 160GB to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for iPod classic 160GBweBoost NMO Antenna 800/1900 MHz Omni Directional for iPod classic 160GB
CAD 19.99  $26.99'Not yet rated.'Ships 1/19Add weBoost NMO Antenna 800/1900 MHz Omni Directional for iPod classic 160GB to Cart
weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPod classic 160GBweBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPod classic 160GB
Wilson Electronics 901101 NMO Cellular Antenna Trunk Mount with cable allows you to mount any NMO Cellular Antenna to a trunk lid or window.
CAD 13.99  $24.99'Not yet rated.'In StockAdd weBoost NMO Trunk Mount w/14 RG58U cable - FME (901101) for iPod classic 160GB to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPod classic 160GBweBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPod classic 160GB
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for iPod classic 160GB to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPod classic 160GBweBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPod classic 160GB
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for iPod classic 160GB to Cart
weBoost Marine Antenna Mount (901119) for iPod classic 160GBweBoost Marine Antenna Mount (901119) for iPod classic 160GB
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for iPod classic 160GB to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPod classic 160GBweBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPod classic 160GB
CAD 9.99  $9.99'Not yet rated.'Ships 1/19Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for iPod classic 160GB to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPod classic 160GBweBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPod classic 160GB
CAD 11.99  $14.99'Not yet rated.'Ships 1/19Add weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for iPod classic 160GB to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPod classic 160GBweBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPod classic 160GB
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for iPod classic 160GB to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPod classic 160GBweBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPod classic 160GB
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for iPod classic 160GB to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPod classic 160GBweBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPod classic 160GB
CAD 39.99  $49.99'Not yet rated.'Ships 1/19Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for iPod classic 160GB to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPod classic 160GBweBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPod classic 160GB
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 1/19Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for iPod classic 160GB to Cart
weBoost DC 12v Hardwire Power Kit for iPod classic 160GBweBoost DC 12v Hardwire Power Kit for iPod classic 160GB
CAD 7.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for iPod classic 160GB to Cart
weBoost DC/DC 6 volt Power Supply for iPod classic 160GBweBoost DC/DC 6 volt Power Supply for iPod classic 160GB
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for iPod classic 160GB to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPod classic 160GBweBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPod classic 160GB
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for iPod classic 160GB to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPod classic 160GBweBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPod classic 160GB
CAD 19.99  $26.99'Not yet rated.'In StockAdd weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for iPod classic 160GB to Cart
weBoost Home Accessory Kit for Sleek Amp for iPod classic 160GBweBoost Home Accessory Kit for Sleek Amp for iPod classic 160GB
CAD 29.99  $49.99'Not yet rated.'In StockAdd weBoost Home Accessory Kit for Sleek Amp for iPod classic 160GB to Cart
weBoost Battery Pack for iPod classic 160GBweBoost Battery Pack for iPod classic 160GB
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for iPod classic 160GB to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPod classic 160GBweBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPod classic 160GB
CAD 35.99  $35.99'Not yet rated.'Out of StockAdd weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for iPod classic 160GB to Cart
weBoost Adjustable Suction Cup Mount for iPod classic 160GBweBoost Adjustable Suction Cup Mount for iPod classic 160GB
CAD 23.99  $27.99'Not yet rated.'Ships 1/19Add weBoost Adjustable Suction Cup Mount for iPod classic 160GB to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPod classic 160GBweBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPod classic 160GB
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for iPod classic 160GB to Cart
weBoost 4G-X OTR Drive Kit for iPod classic 160GBweBoost 4G-X OTR Drive Kit for iPod classic 160GB
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Pre-OrderAdd weBoost 4G-X OTR Drive Kit for iPod classic 160GB to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPod classic 160GBweBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPod classic 160GB
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for iPod classic 160GB to Cart
My iPod classic 160GB
Shop by Category
Customer Care
Powered by...
Our Customers Say...
