The new iPad Spare Parts
Browse Spare Parts for The new iPad
Sort by:
Narrow By:
weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for The new iPadweBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for The new iPad
CAD 34.99  $45.99'Not yet rated.'Ships 5/3Add weBoost Magnetic Antenna - dual band 800/1900 - 10 foot cable - FME (301103) for The new iPad to Cart
weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for The new iPadweBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for The new iPad
CAD 29.99  $32.99'Not yet rated.'Out of StockAdd weBoost Mini Magnet-Mount Antenna - 800/1900 - 10 foot Cable - FME (301113) for The new iPad to Cart
weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for The new iPadweBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for The new iPad
CAD 29.99  $35.99'Not yet rated.'Ships 5/3Add weBoost Mini Magnet Antenna 800/1900 - 10 Foot Cable - SMA (301126) for The new iPad to Cart
weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for The new iPadweBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for The new iPad
Free Shipping
CAD 58.99  $58.99'Not yet rated.'Ships 5/3Add weBoost Cradle Plus Antenna W/SMA Connector 800/1900 MHz for The new iPad to Cart
weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for The new iPadweBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for The new iPad
CAD 34.99  $44.99'Not yet rated.'Ships 5/3Add weBoost Low Profile Antenna 800/1900 MHz w/ 10 ft. RG174 Cable and SMA Connector for The new iPad to Cart
weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for The new iPadweBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for The new iPad
Free Shipping
CAD 54.99  $68.99'Not yet rated.'Out of StockAdd weBoost Glass Mount Antenna - dual band 800/1900 - 14 foot Cable - SMA Male for The new iPad to Cart
weBoost NMO Antenna 800/1900 MHz Omni Directional for The new iPadweBoost NMO Antenna 800/1900 MHz Omni Directional for The new iPad
CAD 19.99  $26.99'Not yet rated.'Ships 5/3Add weBoost NMO Antenna 800/1900 MHz Omni Directional for The new iPad to Cart
weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for The new iPadweBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for The new iPad
CAD 11.90'Not yet rated.'Out of StockAdd weBoost 3 Way Mount with Spade Stud For Trucker Antenna (901104) for The new iPad to Cart
weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for The new iPadweBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for The new iPad
CAD 6.99  $14.99'Not yet rated.'In StockAdd weBoost Horizontal Mount with Spade Stud (for Wilson Trucker Antenna) (901106) for The new iPad to Cart
weBoost Marine Antenna Mount (901119) for The new iPadweBoost Marine Antenna Mount (901119) for The new iPad
CAD 29.99  $39.99'Not yet rated.'Out of StockAdd weBoost Marine Antenna Mount (901119) for The new iPad to Cart
weBoost Suction Cup Window Mount for Magnet Antennas (901128) for The new iPadweBoost Suction Cup Window Mount for Magnet Antennas (901128) for The new iPad
CAD 9.99  $9.99'Not yet rated.'Ships 5/3Add weBoost Suction Cup Window Mount for Magnet Antennas (901128) for The new iPad to Cart
weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for The new iPadweBoost In-Vehicle Cradle Plus Mounting Kit (901134) for The new iPad
CAD 11.99  $14.99'Not yet rated.'In StockAdd weBoost In-Vehicle Cradle Plus Mounting Kit (901134) for The new iPad to Cart
weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for The new iPadweBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for The new iPad
Free Shipping
CAD 69.99  $129.99'Not yet rated.'In StockAdd weBoost Omni Building Antenna Kit for Router Hubs w/ 30 Foot Cable 50 Ohm FME/MCX/SMA for The new iPad to Cart
weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for The new iPadweBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for The new iPad
Free Shipping
CAD 99.99  $169.99'Not yet rated.'In StockAdd weBoost Yagi Antenna Kit for Router Hubs w/50 Foot Cable 50 Ohm MCX/SMA for The new iPad to Cart
weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for The new iPadweBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for The new iPad
CAD 39.99  $49.99'Not yet rated.'Ships 5/3Add weBoost Mini Magnet Antenna Kit for Router Hubs w/10 foot Cable FME/MCX/SMA for The new iPad to Cart
weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for The new iPadweBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for The new iPad
Free Shipping
CAD 349.99  $379.99'Not yet rated.'Ships 5/3Add weBoost (Dual Band Mobile Wireless) 800/1900 In-Vehicle Amplifier - SMA for The new iPad to Cart
weBoost DC 12v Hardwire Power Kit for The new iPadweBoost DC 12v Hardwire Power Kit for The new iPad
CAD 9.99  $14.99'Not yet rated.'In StockAdd weBoost DC 12v Hardwire Power Kit for The new iPad to Cart
weBoost DC/DC 6 volt Power Supply for The new iPadweBoost DC/DC 6 volt Power Supply for The new iPad
CAD 37.99  $48.99'Not yet rated.'Out of StockAdd weBoost DC/DC 6 volt Power Supply for The new iPad to Cart
weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for The new iPadweBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for The new iPad
CAD 19.99  $39.99'Not yet rated.'In StockAdd weBoost Portable Amplifier Vented Soft Carrying Case (Holds 2 Batteries) for The new iPad to Cart
weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for The new iPadweBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for The new iPad
CAD 19.99  $26.99'Not yet rated.'Ships 5/3Add weBoost AC/DC Power Supply for C-Booster, U-Booster and Sleek Univ for The new iPad to Cart
weBoost Battery Pack for The new iPadweBoost Battery Pack for The new iPad
CAD 24.99  $29.99'Not yet rated.'Out of StockAdd weBoost Battery Pack for The new iPad to Cart
weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for The new iPadweBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for The new iPad
CAD 35.99  $35.99'Not yet rated.'Ships 5/3Add weBoost DC Hardwire Power Supply 5v/1.5A For Use With Sleek and Data Pro Signal Boosters for The new iPad to Cart
weBoost Adjustable Suction Cup Mount for The new iPadweBoost Adjustable Suction Cup Mount for The new iPad
CAD 23.99  $27.99'Not yet rated.'Ships 5/3Add weBoost Adjustable Suction Cup Mount for The new iPad to Cart
weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for The new iPadweBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for The new iPad
CAD 30.99  $30.99'Not yet rated.'Out of StockAdd weBoost Adjustable Desk Mount For Use With Sleek and Mobile Pro for The new iPad to Cart
weBoost 4G-X OTR Drive Kit for The new iPadweBoost 4G-X OTR Drive Kit for The new iPad
Free Shipping
CAD 844.99  $849.99'Not yet rated.'Ships 5/3Add weBoost 4G-X OTR Drive Kit for The new iPad to Cart
weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for The new iPadweBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for The new iPad
Free Shipping
CAD 214.99  $219.99'Not yet rated.'Pre-OrderAdd weBoost 3G M2M Signal w/ Mini Mag Mount Kit 800/1900 for The new iPad to Cart
My The new iPad
Shop by Category
Customer Care
Powered by...
Our Customers Say...
